Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 03-23-2010, 17:32   #1 (permalink)
Member: 146708
Sonork: 100.108221
PM Auth is Woking..?
hi supporters..
service is working..? sx4 Auth.?
Old 03-23-2010, 17:41   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
server is working well, what is problem you're face ?
Old 03-23-2010, 17:53   #3 (permalink)
Member: 146708
Sonork: 100.108221
security test fail.. i have to write pm... but always i m getting server or another errror..
step 1 fail..
Old 03-23-2010, 17:55   #4 (permalink)
Member: 146708
Sonork: 100.108221
step 1 fail..
Trying to authenticate PM...
Connecting to server: BB5 PM Auth
Elapsed time: 2,3 sec.
Step1 failed.
Aborting process...
Old 03-23-2010, 20:34   #5 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
have you check your phone Simlock Status or also Sd ? kindly check sd or simlock status
Old 03-23-2010, 21:34   #6 (permalink)
Member: 146708
Sonork: 100.108221
yes i checked them..fine..what is ur advice.? or what is the pb..?
Old 03-23-2010, 21:41   #7 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
post here log, read info. log, sd check log, or also self test log then i able to check exactly
Old 03-24-2010, 09:29   #8 (permalink)
Member: 192236
ya ..me too hv this problem...simlock data ok,,sd ok..but cant write pm...step 1 fail
Old 03-24-2010, 09:31   #9 (permalink)
Member: 192236
my phone show contact retailer
Old 03-24-2010, 09:42   #10 (permalink)
Member: 192236
cant write pm auth....
Old 03-24-2010, 12:22   #11 (permalink)
Member: 146708
Sonork: 100.108221
read info...
TBB5ReadInfoThread 2.8.5.2522 started at: 2010.03.24 13:18:16
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing phone...
Output power at Line1 3,97V is in range of: 4,00V ±10,0%
Phone powered.
Reading Info...
Soft Version: V 07.30 Date: 07-05-09 Type: RM-217 (6300) Pack: (c) Nokia.
Product code: 0546632
Product code: 0537040
Radio: GSM900 / GSM1800 / GSM1900
Original IMEI: 356857-02-********
Production serial: DJG259850
HW Version: 1000
DSP Version: ICPR61_08w10
LCD Version:
APE ADSP Version:
SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118]
Profile bits: 8000000000000006
Simlock config: 2440700000000000
 Invalid codes entered: 0 / 0
 Block: 1; Lock: 1; State: Open; Data: FFFFFF
 Block: 2; Lock: 1; State: Open; Data: FFFFFF
 Block: 3; Lock: 1; State: Open; Data: FFFFFF
 Block: 4; Lock: 1; State: Open; Data: FFFFFF
 Block: 5; Lock: 1; State: Open; Data: FFFFFF
 Block: 6; Lock: 1; State: Open; Data: FFFFFF
 Block: 7; Lock: 1; State: Open; Data: FFFFFF
 All locks are open.
Security code: 12345
TBB5ReadInfoThread 2.8.5.2522 finished at: 2010.03.24 13:18:55
Done.
SD info..
TBB5CheckSDThread 2.8.5.2522 started at: 2010.03.24 13:19:00
Reading Info...
HW Version: 1000
LCD Version:
APE ADSP Version:
 All locks are open.
Reading PM...
Superdongle data exists--------------------------------------------------------------------------------
TBB5CheckSDThread 2.8.5.2522 finished at: 2010.03.24 13:19:31
Done.
this is SELF TEST..
TBB5SelfTestThread 2.8.5.2522 started at: 2010.03.24 13:19:49
Reading Info...
HW Version: 1000
LCD Version:
APE ADSP Version:
 All locks are open.
Executing self tests...
Passed [0C]  ST_EAR_DATA_LOOP_TEST
Passed [0D]  ST_SIM_CLK_LOOP_TEST
Passed [0F]  ST_SIM_IO_CTRL_LOOP_TEST
Passed [2E]  ST_SLEEP_X_LOOP_TEST
Passed [07]  ST_UEM_CBUS_IF_TEST
Passed [16]  ST_KEYBOARD_STUCK_TEST
Passed [14]  ST_CAMERA_IF_TEST
Passed [15]  ST_BACKUP_BATT_TEST
Passed [2C]  ST_LPRF_IF_TEST
Passed [02]  ST_LPRF_AUDIO_LINES_TEST
Passed [2A]  ST_CURRENT_CONS_TEST
Passed [45]  ST_RADIO_TEST
Passed [21]  ST_BACKLIGHT_TEST
Passed [5D]  ST_SIM_LOCK_TEST
Fail [47]  ST_SECURITY_TEST
Passed [60]  ST_BT_WAKEUP_TEST
Passed [58]  ST_HOOKINT_TEST
Passed [38]  ST_TAHVOINT_TEST
Passed [65]  ST_SLEEPCLK_FREQ_TEST
Passed [6B]  ST_BTEMP_TEST
Passed [6C]  ST_BT_SLEEP_CLK_TEST
Passed [56]  ST_EXT_DEVICE_TEST
Not executed [53]  ST_CDSP_RF_BB_IF_TEST
Not executed [55]  ST_CDSP_RF_SUPPLY_TEST
Not executed [4A]  ST_CDSP_TX_IQ_TEST
Not executed [4F]  ST_CDSP_TXC_DATA_TEST
Not executed [50]  ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Not executed [51]  ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Not executed [4D]  ST_CDSP_RX_IQ_LOOP_BACK_TEST
Not executed [00]  ST_CDSP_GSM_TX_POWER_TEST
TBB5SelfTestThread 2.8.5.2522 finished at: 2010.03.24 13:20:10
Done.
TUniversalForm 2.8.5.2522 finished at: 2010.03.24 13:20:19
Old 03-24-2010, 12:29   #12 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
YOU KLICK SDsx4 Auth AND WRIT PM
Old 03-24-2010, 12:31   #13 (permalink)
Member: 146708
Sonork: 100.108221
but sd is exist why..? pb is sd..?
Old 03-24-2010, 12:32   #14 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Use anther tool...........................................
Old 03-24-2010, 12:48   #15 (permalink)
Member: 146708
Sonork: 100.108221
i did.. not success..
BB5 PM AUTH is not working one9 Universalbox 4 10-02-2009 09:43
Pm auth is problem AYAZ42 Universalbox 0 07-15-2009 15:28
PM AUTH is not working ROMAB Universalbox 6 03-21-2009 12:52
PM Auth is work TITO Universalbox 2 11-18-2007 20:51
Page generated in 0.72681 seconds with 12 queries
