Problem with old patchs for nokia, with nokia 3200 and 3220 v03.60 - dead phones!!! Hello. I'm having problems with these phones, since the last update i can't repair imei on these models as before. I put new imei and the process starts, but at the last step, when the phone is powered in local mode and it gets unlocked, the phone fails to power on, and the program shows up the screen that can't power the phone, OK, RETRY, CANCEL. The phones was OK before patching. I have to flash them to make the phones working again, i repeated the process of patching and phone is dead again... always stop at last step of the procedure. Please HELP!!! |
Hi, For me, it is working perfect. Code: TDCT4ChangeIMEIThread started at: 2007.06.13 15:05:00 |
Code: TDCT4ChangeIMEIThread started at: 2007/06/13 10:39:40 tested today with another 3200 |
with best regards alex |
no, it is log from a nokia 3200, i have problem with 5 3200 from my clients, the phone was working fine, without uem problem... now phones are dead, i have to reflash them to get them working again, after flash i tried to do patch again but phone dead again please solution! |
i tried with nokia 3200 and nokia 3220 v03.60 i can do these phones before the latest upgrade of u.b. |
Hi, As you see, I made 3220 v03.60, without problem. Please post log, i like to see the flash types. Br. |
Hi, Seems we found the bug. It will be fixed in the next release. Br. |
Thanks, please fix it :) |
Problem Id Hardware EL PROBLEMA ES QUE LA UNIVERSAL BOX IDENTIFICA DOS TIPOS DE MODELOS DIFERENTES DE HARDWARE UNIVERSALBOX --------------------- MCU Nokia Version: 1.122, and up to date. SMCU Nokia Version: 1.42, and up to date. Input power: 4,91V OK. Hardware ID: 1130 <-------------------------------DIFERENTE HARDWARE Boot Loader: u_2nd.fia 2 kB Version: 4.61.0 /////////////////////////////////////////////////// DJICE ------------------ MCU Nokia Version: 1.122, and up to date. SMCU Nokia Version: 1.42, and up to date. Input power: 12,30V OK. Hardware ID: 2142 <-------------------------------DIFERENTE HARDWARE Boot Loader: u_2nd.fia 2 kB Version: 4.61.0 |
@powerbook maybe UPP version is different but i doesnt matter before...patching is ok but now maybe new patching will be the answer so try to use your old exe's. |
does anybody have an old exe file ??? i have some phones to do with old patching method... i can't wait for update |
Hi, Please try to patch your phone like this: 1, Flash the phone 2, check only the "patch software" and press "do job" 3, check only the IMEI / ESN and press "do job". Br. |
i tried that method but no success... can you post an old exe file ? i have 10 phones to do :( |
Hi, I dont have them. Br. |
