Universalbox Universalbox Official support area |
02-05-2006, 20:24 | #1 (permalink) |
No Life Poster Join Date: May 2004
Member: 64893 Status: Offline Thanks Meter: 221 | How To W900 Unlock? it asks for testpoint but where is the image?? [URL="http://xxxxxxxxxxxxxxx[/URL] Last edited by Kima; 03-05-2006 at 15:07. |
03-02-2006, 10:36 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 47
Member: 41491 Status: Offline Thanks Meter: 28 | question can W900 be unlock now by UB by TP??? if yes, where to connect the TP needle to the cable or box? pls answer universalbox pls... cause the k750 cable has no TP needle... WBR, |
03-03-2006, 02:42 | #7 (permalink) |
Member: 41491 Status: Offline Thanks Meter: 28 | Thanks AL, but my question is or does the needle NEEDED TO BE CONNECTED TO BOX OR CABLE and not where the TP is?? I know already where the TP was.. again thanks for help.. WBR, |
03-04-2006, 17:45 | #8 (permalink) | |
Member: 64893 Status: Offline Thanks Meter: 221 | Quote:
Anyway, I have succeeded unlocking W900. There are 3 testpoints that need to be connected to any metal shield on the pcb then disconnected once program instructs you to disconnect. www.xxxxxxxx Last edited by Kima; 03-05-2006 at 15:08. | |
03-10-2006, 03:29 | #13 (permalink) |
Member: 64893 Status: Offline Thanks Meter: 221 | Handset unlocked perfectly. You just use the testpoint selection and connect the three testpoints to ground when program tells you to. Bit tricky at the resistor but apart from that...allow 5 mins to open handset, 10 mins for testpoints process and 5 mins to close handset back up. Mark the cable connectors to make sure you place them back into the correct sockets on the inside of the handset. Brightmobile.com |
03-10-2006, 03:55 | #14 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | Quote:
can you tell us which testpoint did you use? and does one TP do the trick or need at least three as mentioned by Cairnquay?? Thanks for reply Al.. BR, epic | |
************* How to enter unlock codes -=- How to Master Reset & More************ | F C | Xpresscodes.com | 4 | 06-09-2009 01:58 |
How to input unlock code correct - Got the code but cant remember how to | Svend Rugaard | Nokia Base Band 5 ( BB-5 ) | 3 | 02-06-2007 01:40 |
how to enter unlock code to blackbarry 7100g | wiliam | FuriousGold | 1 | 11-29-2006 21:53 |
Question: How to SP-unlock A55 that is upgraded to C55? | lexthekjex | E-Gold Based Phones | 2 | 12-20-2003 17:53 |
want to know how to make unlocked partial flash files | wildwhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-22-2001 18:36 |
