Universalbox Universalbox Official support area |
04-12-2009, 02:06 | #3 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Recife - Brazil
Member: 434450 Status: Offline Thanks Meter: 51 | yes i tryed whit fbus and surprise got dead phone and after that i cant flash it even by usb i need to flash it whit another box to revive flash only by usb or you will have a sad surprise |
04-12-2009, 23:05 | #5 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | if you're sure your phone have a Software Fault check battry Directly Connect Usb Cable in your pc Hub Connect phone Press Flash (kindly check DEAD USB FLASHING) Keep Press Power Button PS: you need to install nokia usb Drivers for usb flashing or you can use for drivers (latest Nokia PC suite) |
04-13-2009, 01:14 | #6 (permalink) | |
Insane Poster Join Date: May 2007 Location: indonesia
Member: 519175 Status: Offline Sonork: 100.1592643 Thanks Meter: 17 | Quote:
Yes,you're right sir,in some BB5 phone.there're still bugs and 'failed' problem.in this case,flashing is with Fbus cable.in usb mode,as long as I try,everything are ok.please,fix all buggy problem.mostly in N70,and BB5+,and some BB5 non OS based.thanks | |
Is it possible to clone sim without having direct access to it??? | BilalMehdi | Sim Cloning and Scaning | 2 | 09-15-2008 11:25 |
question ?? is it possible to convert smartunlocker to smartclip | zakovb | Smart-Clip | 1 | 06-09-2006 09:21 |
Is it possible to flash 8130 v 106+ , please post just if you did it already | gsmnice | LG | 8 | 04-13-2005 01:17 |
T610 is it possible to unlock or does it have TP ? | Gsmhq | Twisterflasher | 10 | 08-21-2004 16:15 |
Is it possible to lock phone again, as it was then I bought it? | jonis2002 | x1x to x45/x50 | 4 | 09-27-2002 21:17 |
