Universalbox Universalbox Official support area |
06-24-2006, 09:05 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 43
Member: 147007 Status: Offline Thanks Meter: 8 | Killed 3220b with UB |
06-25-2006, 08:06 | #2 (permalink) |
Freak Poster Join Date: May 2006 Location: neverland, WT 1982 Age: 42
Member: 279611 Status: Offline Thanks Meter: 4 | @ djssergy flash the phone again in a higher or later version (MCU+UCP+PPM+PP) check out your cable also... if it asks you to MANUAL POWER ON THE PHONE use another cable... i've done this for several times and happy to say that i haven't met this kind of problem using my UNIBOX... thanks and hope this might help you abit... wbr... warblades |
06-26-2006, 13:42 | #3 (permalink) | |
No Life Poster Join Date: Jun 2004 Age: 48
Member: 68982 Status: Offline Thanks Meter: 17,853 | Quote:
06-27-2006, 02:32 | #6 (permalink) |
Member: 279611 Status: Offline Thanks Meter: 4 | If changing another cable didn't work try to clean the contacts (pinout contacts) of the phone... check also your usb connection... wbr... warblades |
07-07-2006, 11:16 | #7 (permalink) |
Member: 147007 Status: Offline Thanks Meter: 8 | the problem was: i tried to flas a rh49 v 5.01 with rh49 v3.60 but any tie i do this killed phone result. The solution was: fllsh the phone with the rh37 v5.01 an voila PHONE LIVES NOW.. |
07-24-2006, 09:46 | #8 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi I have the same problem. I try to downgrade a phone version to 3.60 but the phone is killed. Now I follow your instructions but the phone is blinking ! Turn on and off with a Simcard but without sim its ok ! Pls help me ! Many thanks |
nokia e 71 more are killed with ub box to not start? us and give someone new a soluti | ciopa | Universalbox | 14 | 04-16-2009 16:30 |
Nokia e71 killed with ub need help | voicelink | Universalbox | 1 | 04-03-2009 11:58 |
SE w200 sid 52 Killed with UB box | cesarus | Sony Ericsson | 1 | 10-27-2007 11:05 |
W600i killed with ub after unlock | nofear197979 | Universalbox | 6 | 06-16-2006 14:56 |
