rm-578 2730c-1 flashing problem I tried flash to 2730 phone but phone is dead please help. TBB5USBFlashThread 2.8.9.2680 started at: 2010/08/24 22:54:51 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device --- Press phone's power button! --- Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 308032 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Asic CMT: Start programming 39990 KB... Asic CMT: Erasing rm578__09.41.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing rm578__09.41.ppm_m_c Asic CMT: Erasing area 1... Aborting process... Warning: User called Unsafe Abort! Aborting flashing Warning: Unsafe Abort detected! Aborting flashing now!! Error ERASE_AREA: 0x01760000 - 0x01FFFFFF Asic CMT: Error in sending data from rm578__09.41.ppm_m_c. Protocol 1: Error during Flashing. Unable to continue. Unable to flash phone 0x84012281 -------------------------------------------------------------------------------- TBB5USBFlashThread 2.8.9.2680 finished at: 2010/08/24 23:06:19 Aborted by user. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQYY7Y8] TBB5USBFlashThread 2.8.9.2680 started at: 2010/08/24 23:06:22 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device --- Press phone's power button! --- Aborting process... Warning: User called Unsafe Abort! Aborting flashing Warning: Unsafe Abort detected! Aborting flashing now!! Failed to send wait request! |
try to use fully charge bettry also connect charger or try again |
I tried many times with fully charger battery and connected charger but BB5USBFlashThread 2.8.9.2680 started at: 2010/08/25 04:58:11 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device --- Press phone's power button! --- Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 308032 bytes Update server loaded Error initializing Algorithm. 0x84009427 -------------------------------------------------------------------------------- TBB5USBFlashThread 2.8.9.2680 finished at: 2010/08/25 04:59:09 Terminated with error: Unable to get error message [00010123] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQYY7Y8] |
