Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 07-15-2009, 01:42   #1 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
How to Enter Unlock Codes in Samsung Phones
If you received two unlock codes the first one is Unfreeze code. The second code is Network Unlock Code (NCK). If you received only one code from us it's a Network Unlock Code (NCK).
How to remove Phone freeze
A frequent reason for Freeze Code to be enabled is when user enters several erroneous NCK codes.
If your cell phone shows a "Phone Freeze" message use the first code to unfreeze it. Enter the 8-digit code with SIM card in the phone when the "Phone Freeze" message is displayed, then press OK button (middle buttom, depending on phone branding can be called differently).
You will not see text appear on screen while typing.
You can now proceede to entering Network Unlock Code.
How to enter Network Unlock Code
Samsung Z510, Z650, Z320i
  1. Power on without SIM card
  2. Type in **CODE# where CODE is the unlock code you received from XXXXXXXX
Samsung Z105 and Z107
  1. Power on with a non accepted SIM card
  2. Type in #7465625*638*CODE# (or *#7465625*638*CODE#) where CODE is the unlock code you received from XXXXXXXX
  3. Press the SEND key, display should read, "Personalization Cancelled"
Samsung 3G series, D, Z-series, some A-, C-, E-, T-, X-series, other models
Samsung i450 & i560 and I8910
  1. Switch ON your phone without SIM Card,
  2. Compose #PW+CODE+1#
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
Samsung i780
  1. Insert an unaccepted SIM card
  2. Enter the pin code to simcard (if enable pin code)
  3. At the top of screen an "exclamation mark" icon will appear
  4. Click on "exclamation mark" icon
  5. There will appear link "settings" - click on it
  6. Virtual keyboard appears on screen with Enter PIN prompt.
  7. Enter your 8-digit unlock code.
SAMSUNG P777, D357 , D807, D407
  1. Power on without sim,
  2. type in #0111*unlock code#
ZX10, ZX20, A707, A437, X497, C417
  2. type in #7465625*638*Unlock code#
How to ENTER CODES in S5320 ?
  1. Insert WRONG simcard inside the phone .
  2. Press CALL Button so digit will be displayed .
  3. Enter your FREEZE Codes and Press CALL/# button in keypad .
  4. If phone ask for NCK/SP codes just type the codes like this. #0111*NCK# #0141*SIMLOCK#
Other Samsung models
  2. Phone will ask for "Password"
  3. Enter the unlock code you received from XXXXXXXX
    Note: In some instances the phone won't ask for "Password" - enter the unlock code anyway
OR if phone shows "Insert Correct SIM card"
  2. Type in #0111*CODE# where CODE is the unlock code you received from XXXXXXXX
i607 Blackjack
Power on with incorrect (non accepted) SIM card, when asked to enter network pin enter provided unlock code.
No need to hold other keys while entering code
If you are unable to connect to the service provider or unable to make out-going calls or receive messages, this has nothing to do with your phone being locked. You need to force the Blackjack to change to GSM mode:
  1. Power on the phone
  2. Enter *#1546792*#
  3. Select Option 3 Network & Call Settings
  4. Select Option 5 Network Mode
  5. Select GSM
NOTE: ALL SAMSUNG unknown phones is supported for unlock by Imei in UNIVERSALBOX, only SOFTBANK (Japanese) phone not supported,
Best Regards
Universal Box Team
The Following 13 Users Say Thank You to Ja\/\/aD For This Useful Post:
can the samsung 360 be unlocked my codes on samsung nck jjsweets Universalbox 0 01-29-2010 12:44
SAMSUNG NCK unlock can be used when 27977779 Universalbox 0 08-05-2009 10:46
dct4+ & samsung NCK not work mefisto23cj Universalbox 0 08-05-2009 07:39
How to cancel samsung NCK calc ??? johnny_liang Universalbox 0 08-03-2009 06:03
samsung nck jodge allGSMunlock MultiOnline Remote Server 1 07-27-2009 09:53
Page generated in 0.34815 seconds with 11 queries
