Universalbox Universalbox Official support area |
02-28-2010, 10:26 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | actually you have 2 button for pm auth, No. 1 in right side bb5/maintenance if super dongle is valid or not repaired then you need to use Old Pm auth button, right side No. 2 under in sd maintenance, if you have Calculate Sd with Ub then you need to use this button, |
03-01-2010, 14:38 | #5 (permalink) | |
Insane Poster Join Date: Dec 2007 Location: IRAN
Member: 652617 Status: Offline Thanks Meter: 10 | Quote:
one of them(N73) simlock is invalid after I repair it all thing(Imei,simlock,self test) is ok but when I turn on it phone is: phone start-up failed... I conect phone again and do Read Info simlock again invalid How can I repair this problems? | |
03-02-2010, 12:46 | #9 (permalink) | |
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | Quote:
if you don't have write Pm 1-309 with Sx, Check SD First or Write pm with SX Posiblity:2 dependon your HWC, CCC Data i mean if in your phone has bad HWC, CCC Data that's way possible to face like that problem, | |
e62.repair sd data & security data ok.but still contect retaile | APOLLO MOBILE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-10-2010 16:02 |
what can i do when simlock is invalid but SD is existing | GSM SNIPER | Universalbox | 6 | 01-05-2010 15:58 |
after calculat sd 30 cradit is gon but no pm auth | hajukhan | Universalbox | 1 | 12-13-2009 17:41 |
N73 SimLock Data OK But imei is still Damaged... | LoveLess | Nokia Base Band 5 ( BB-5 ) | 6 | 05-14-2008 20:37 |
