Universalbox Universalbox Official support area |
11-04-2006, 13:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: sibiu
Member: 167213 Status: Offline Thanks Meter: 21 | sonyericsson k800i no power |
11-04-2006, 14:09 | #3 (permalink) |
Member: 167213 Status: Offline Thanks Meter: 21 | i took it and i put it i disconected the cable and reconected.and it doesn't work.i change the battery or i put the external power on battery.is the same.no work.what can be broken? |
11-04-2006, 14:31 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: www.sw-box.com Age: 19
Member: 152573 Status: Offline Thanks Meter: 58 | hi mate, take out baterry and put back then plug out the cable from phone and plug in again. if it still didnt boot mean ur k800 maybe security area damage, no solution for all flashing device on the market. please send for warranty Regards alex |
11-04-2006, 19:34 | #9 (permalink) |
Member: 167213 Status: Offline Thanks Meter: 21 | [QUOTE=EIGY;2069080]Hello! Ma8! Pls! Post here Info log and Flashing log! i can't read info from phone because what ever i want to do the phone must be on and i have only a red led from irda light.doesn't exist a little trick for this? |
11-04-2006, 19:44 | #10 (permalink) |
Junior Member Join Date: Jan 2004
Member: 49575 Status: Offline Thanks Meter: 0 | if the sw is damaged, you cannot charge the battery with the phone. check the battery voltage with a multimeter, it must be around 3.8v. if the battery is ok, then put into the phone, and check try to turn on the phone, and check the charging led. if it is not blinking then 2 thing can be: 1, the erom is ok, but you have sw problem. 2, the phone is totally dead. if the led blinks it means the erom is damaged. if the first case happens, you can repair the phone by flashing the latest sw to it. |
11-04-2006, 23:34 | #11 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: london Age: 56
Member: 98828 Status: Offline Thanks Meter: 76 | Quote:
BR gsmuk | |
11-05-2006, 04:15 | #13 (permalink) | |
Member: 152573 Status: Offline Thanks Meter: 58 | Quote:
but the main problem is now this k800 look like security area damage, nothing to do.. send for Sony ericsson facotry for warranty | |
k800i no power,plss help!!!.. | nath15 | Universalbox | 1 | 12-10-2008 10:16 |
sonyericsson k800i no network | amanvir | SETool2 | 16 | 08-01-2008 18:07 |
k800i no power | TIGZIRT | SETool2 | 5 | 05-24-2008 07:15 |
how to repair se k800i no power-red blinking and not posibility to conect | lalasdj | Sony Ericsson | 22 | 11-23-2007 08:13 |
