Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 11-15-2008, 18:35   #1 (permalink)
Braycel's Avatar
Member: 813309
That step with the server simbyam s60
THAT STEP WITH THE SERVER SIMBYAM S60
TBB5OnlineS60UnlockThread started at: 2008/11/15 13:31:20
MCU Nokia Version: 1.124, and up to date.
SMCU Nokia Version: 1.42, and up to date.
Detecting BB5 USB device...
Reading Info...
MCU Version: V 03.27 Date: 07-09-07 Type: RM-302 (5700b XPRESS MUSIC) Additional_1: (c) Nokia [Nokia 5700b XPRESS MUSIC CABLE 5700]
PPM Version: V 03.27 Date: 07-09-07 Type: RM-302 (5700b XPRESS MUSIC) Pack: (c) Nokia
Product code: 0549312
Original IMEI: ******************
Production serial: CLE016446
HW Version: 0206
DSP Version: pb06w41v24.3_rm302
LCD Version:
APE ADSP Version: 256
SIMLock service: SIMLOCK SERVER [040A0C060A04]
Profile bits: 8000000000000000
Simlock config: 7340400023927779
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Closed; Data: 73404F
Block: 2; Lock: 1; State: Closed; Data: 74000F
Block: 3; Lock: 1; State: Closed; Data: 732123
Block: 4; Lock: 1; State: Closed; Data: 71606F
Block: 5; Lock: 1; State: Closed; Data: 21407F
Block: 6; Lock: 1; State: Closed; Data: 21402F
Block: 7; Lock: 1; State: Closed; Data: 73002F
Block: 8; Lock: 1; State: Closed; Data: 72207F
Block: 9; Lock: 1; State: Closed; Data: 74807F
Block: 10; Lock: 1; State: Closed; Data: 33403F
Block: 11; Lock: 1; State: Closed; Data: 70403F
Block: 12; Lock: 1; State: Closed; Data: 70604F
Block: 13; Lock: 1; State: Closed; Data: 71030F
Block: 14; Lock: 1; State: Closed; Data: 71402F
Security code: 12345
You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx
from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite.
After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu
and connect it to your computer by selecting the Options/Connect menu
Uploading application...
Application installed, please press on phone "Options" => "Hello"
Calculating code...
Connecting to server: US1
Credits: XXX
TBB5OnlineS60UnlockThread finished at: 2008/11/15 13:32:56
Terminated with error: Response from server: Error on server side! Please retry later. [00000880].00029114
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Old 11-15-2008, 20:03   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
server overloaded please try again after few time
Old 11-15-2008, 22:01   #3 (permalink)
universalbox's Avatar
Member: 68982
It is working now.
There was just a bit downtime...
will happen with phones that are with the IMEI number in 123456-10-654321? cristhian garci Universalbox 8 11-11-2009 14:11
To Step With The Support Raskal,manole,ubl Team!!! :::MACUGSM::: Ultima Box Light 0 11-10-2007 14:06
Thunder 暴 that change with the language 755 come amiss 25% ll1221 ThunderStorm Box 2 12-06-2005 12:51
AT LAST! - JAVA games that work with the C975!!! gilbo P2k Series 10 07-18-2005 09:27
To mine 616 it became bad That that happened with the transmitter lukasartsDon NEC 0 03-17-2005 09:35
Page generated in 0.37746 seconds with 11 queries
