Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 09-05-2011, 04:25   #1 (permalink)
Member: 1280685
Question Terminated with error: Flash: Boot rom was not detected after phone boot up.
MCU Nokia Version: 1.132, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing flasher...
Initializing
Download files list initiated
Waiting for USB device...
Flash operation failed
TBB5USBFlashThread 2.9.5.2863 finished at: 2011/09/05 11:17:17
Terminated with error: Flash: Boot rom was not detected after phone boot up. Unable to start flashing [00010123]
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->Universal Box [UBR5TMDG]
Old 09-05-2011, 09:18   #2 (permalink)
MobilesDoctor's Avatar
Member: 87357
Sonork: 100.1574043
I think It has hardware fault.
Old 09-05-2011, 09:36   #3 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Initializing
I had same issue with n95 8gb, I solved only by fixing usb connector of the phone.
Old 11-01-2011, 15:52   #4 (permalink)
Member: 454485
i have this problem with nokia 7020 phone is ok working not dead but no flashing???
Old 11-03-2011, 07:06   #5 (permalink)
Member: 1638193
same like that i tried before with 5800 only vibrate in the result is that..but when i try to 6120c put simcard not ok...its work...hardware problem bro
Old 11-03-2011, 07:18   #6 (permalink)
rana_sab's Avatar
Member: 62911
which handset you are trying to flash?
Old 06-28-2012, 04:53   #7 (permalink)
asankkdi@yahoo.'s Avatar
Member: 410877
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
ERROR: BOOTROM NOT DETECTED
BootFlashMode_DCT5
BootFlashMode_DCT5
BootFlashMode_DCT5
READING BOOTROM
Old 06-28-2012, 04:54   #8 (permalink)
Member: 410877
Number of Image Files: 4
Processing Image File :
RM-625_40.1.003_prd.core.C00
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 13000000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 403
Entry Point: 0x289C52
Page Format : -1
MAX PAGE : 0x00040000
RM-625_40.1.003.319.01.rofs3.fpsx
CMT Type : BB5
Number of Blocks : 29
Entry Point: 0x00D7
Page Format : -1
RM-625_40.1.003_prd.rofs2.V25
CMT Type : BB5
Number of Blocks : 109
Entry Point: 0x00D7
Page Format : -1
RM625_40.1.003_001_U319.uda.fpsx
CMT Type : BB5
Number of Blocks : 52
Entry Point: 0x00D1
Page Format : -1
2. Insert USB.
BootFlashMode_DCT5
BootFlashMode_DCT5
BootFlashMode_DCT5
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeded After 4 Tries
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01051105
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 19300004
ID DWORD 1 : A89F0052
ID DWORD 2 : 38758DEE
ID DWORD 3 : 1534F600
ID DWORD 4 : EF2DC1BA
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPIDOv11_ 2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> Type not in database
Revision ID : 0231
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPIDOv11_ XSR15_alg.fg
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
SendCodeStart_NewProtocol
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
7DC72D3FDC552426A4479BC820097D304CFB6C15
START READING RPL DATA
IMEI: 352715046578917
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... EMPTY
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\352715046578917\3527150465789 17_92219.rpl
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-625\
ImageFilename: RM-625_40.1.003_prd.core.C00
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00080000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 02700000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 09E60000
Partition 4
Start Address : 0F640000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000002680000000000040000000202700000077600 00000000080000000109E60000056200000000000A00000001 0F640000003C0000F7
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x5F (95)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00040000-00082FFF
1 : 00083400-003FFFFF
2 : 00400000-007FFFFF
3 : 00800000-00D5FFFF
4 : 00D60000-09E5FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5005120B0003000004000000082FFF120B0003000008340000 3FFFFF120B00030000400000007FFFFF120B00030000800000 00D5FFFF120B00030000D6000009E5FFFFD5
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033
Successfully Erased...
Total blocks to write : 403
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*ENO
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
Old 06-28-2012, 04:57   #9 (permalink)
Member: 410877
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:02:37
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Old 06-28-2012, 09:17   #10 (permalink)
Member: 75876
DEAD usb flashing ERROR
Initializing
Scanning image files...
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 308032 bytes
Update server loaded
TBB5USBFlashThread 3.0.1.2948 finished at: 2012/06/28 13:12:07
Old 06-28-2012, 09:33   #11 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
2. Insert USB.
BootFlashMode_DCT5
BootFlashMode_DCT5
BootFlashMode_DCT5
BootFlashMode_DCT5
READING BOOTROM
WTF ?
Where do you think you are ? Can't you read section's name ?
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
vBulletin Optimisation provided by vB Optimise (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 0.46163 seconds with 8 queries
