Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 08-13-2006, 10:15   #1 (permalink)
Member: 49123
Thanks Meter: 6
Universalbox Dongle Can"t flash nokia
hepl me? Universalbox Dongle not flash all model nokia
thank
Old 08-13-2006, 20:15   #2 (permalink)
EIGY's Avatar
Member: 68075
Thanks Meter: 51
You try this one!
1. Menu "Setup".
2. General.
3. Remove algos from box
4. Menu "Update".
5. Self update.
6. Update.
B.R.
EIGY.
Old 08-14-2006, 01:40   #3 (permalink)
Member: 49123
Thanks Meter: 6
Originally Posted by EIGY View Post
You try this one!
1. Menu "Setup".
2. General.
4. Menu "Update".
5. Self update.
6. Update.
B.R.
EIGY.
thank you very much...B.R
Old 08-14-2006, 16:49   #4 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 396
Ok now Mr Dungrau?
Old 08-25-2006, 22:28   #5 (permalink)
Member: 111115
thank you very much.....HSB
Old 08-27-2006, 05:32   #6 (permalink)
Member: 225758
I have exactly the same problem but this solution (Remove Algos from box) doesn't work for me. I always got this message each time I tried...
Terminated with error: No device opened [00000001]
MCU Boot Version: 1.069, and up to date.
Device open failed at USB->Universal Box [UBOYEZ7S]
Is there any other way?
Old 08-28-2006, 01:52   #7 (permalink)
EIGY's Avatar
Member: 68075
Thanks Meter: 51
hello! Ma8.
You try This one!
1. Remove Algos from box
2. Erese C:Uni/uni.ini
3. Erese C:Un/UBOYEZ7S.ini
4. Re-Start PC not Exit UB.
6. Open UB.
7. Menu Setup.
8. General.
9. Refresh.
10. Apply.
11. Then Menu Update.
12. Self update.
13. Click Update.
14, If, Can not be you try uninstal driver.
B.R.
EIGY.
Old 08-28-2006, 19:27   #8 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 396
Shorten your USB cable please!
Old 08-30-2006, 03:04   #9 (permalink)
edermix's Avatar
Member: 48037
Sonork: edermix
Thanks Meter: 21
Thank You Very Much!!!
Old 08-30-2006, 04:30   #10 (permalink)
Member: 225758
Thanks for all your suggestion but it didn't solve my problem. Fortunately, my box reseller is very kind enough to replace my box. Now I got another brand new working box. And he suggest that I should always connect the power supply because before I only connect it when the box as for it (i.e. during flashing).
Old 10-12-2006, 16:11   #11 (permalink)
Member: 369223
problem universalbox
problem this boot universal
text
mcu boot vercion: 1,069 and up to date
device open failure ot usb
u (ubcddaot)
no solution plese help!!!!!
What is Universalbox Dongle ??? Aamir_Zia Universalbox 48 07-04-2009 11:17
good points and badpoints on universalbox Dongle IR-GSM Universalbox 29 09-20-2006 10:03
Can universalbox solve NEW FLASH IC inside Nokia? Gsm-W Universalbox 5 10-25-2005 23:21
Latest Solutions Available Including ASTRO CLIP + UNIVERSALBOX DONGLE NUGSM Main Sales Section 0 09-22-2005 20:35
Latest Unlocking Solutions including UniversalBox Dongle - Official UK Reseller PremierGSM Main Sales Section 0 09-22-2005 16:44
Page generated in 0.27382 seconds with 11 queries
