Universalbox Universalbox Official support area |
03-24-2011, 16:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2009
Member: 1158839 Status: Offline Thanks Meter: 127 | usb flashing error after update, when process comes to update server loaded, frezee! MCU Nokia Version: 1.128, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 15232 bytes Secondary boot loaded Loading update server code: 2771219 bytes Update server loaded |
The Following User Says Thank You to Fiton For This Useful Post: |
03-24-2011, 16:44 | #2 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 969318 Status: Offline Thanks Meter: 82 | Hi, i have same problem....freezes but when i click on abort process continues...moderator check into this and fix bug asap |
The Following User Says Thank You to big_gsm For This Useful Post: |
03-24-2011, 17:49 | #3 (permalink) | ||
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,689 | Quote:
will be fixed soon read this http://forum.gsmhosting.com/vbb/f305...-soon-1232940/ b.r. | ||
03-25-2011, 06:12 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | Udate done but same...... MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: Main Receiving features info... Connecting to server: Main Receiving latest versions... All available algos are up to date. Current local filepack version: 7.57 is up to date. Current local executable version: 2.9.0.2733 is up to date. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Flashing Log: MCU Nokia Version: 1.128, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 430464 bytes Update server loaded Freez here but after hit Abort button flashing continue..........and done. Aborting process... Warning: User called Unsafe Abort! Aborting flashing Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Asic CMT: Start programming 40934 KB... Asic CMT: Erasing rm443__10.10.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing area 7... Asic CMT: Erasing area 8... Asic CMT: Erasing rm443__10.10.ppm_mb Asic CMT: Erasing area 1... Asic CMT: Erasing rm443__10.10.image_mb_pk_silverbrown Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Programming rm443__10.10.mcusw Asic CMT: Programming rm443__10.10.ppm_mb Asic CMT: Programming rm443__10.10.image_mb_pk_silverbrown Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.1 Backup sub-procedure started: data item post-delay Backup sub-procedure started: data item pre-delay Backup data item started: EmergencyNumbers, version: 1.0 Backup sub-procedure started: data item post-delay Backup sub-procedure started: data item pre-delay Backup data item started: ISSVariantActivator, version: 1.0 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 3 items were not backed up Aborted by user. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQYVI37] |
The Following User Says Thank You to ZubairArain For This Useful Post: |
03-29-2011, 05:40 | #9 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | Fixed now after latest update...........Thanks Update Log: MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: Main Receiving features info... Connecting to server: Main Receiving latest versions... All available algos are up to date. Current local filepack version: 7.57; Upgrading to latest version: 7.60. Connecting to server: Main Receiving file list... Generating file list... Connecting to server: Main Downloading files... Downloading C:\Uni\Files\Nokia\DCT-4\Fia\helen3_1_2nd.fg... Downloading C:\Uni\Files\Nokia\DCT-4\Fia\nomadik8810_2nd.fg... Downloading C:\Uni\Files\Nokia\DCT-4\Fia\RAP3Gv2_algo.fg... Downloading C:\Uni\Files\Nokia\DCT-4\Fia\RAP3Gv2_samsung_nor-nand.fg... Downloading C:\Uni\Files\Nokia\DCT-4\Fia\RAP3Gv2_st_nor.fg... Downloading C:\Uni\Files\Nokia\DCT-4\Fia\RAPGSM_2nd.fg... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_3.01.org... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_3.01.pat... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_3.03.org... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_3.03.pat... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_98_3.01.imp... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_98_3.01.txt... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_98_3.03.imp... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-97_98_3.03.txt... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-98_3.01.org... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-98_3.01.pat... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-98_3.03.org... Downloading C:\Uni\Files\Nokia\DCT-4\Patch\RH-98_3.03.pat... Downloading C:\Uni\Files\setup.ini... 19 important file downloaded sucessfully. Connecting to server: Main Receiving file list... Generating file list... Deleting file: C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd.fl... Connecting to server: Main Downloading files... Downloading C:\Uni\Files\Nokia\BB5\Flash\BCM21352.fg... Downloading C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd\9A28E1 19033B91D14D22838C86D0D53C.ldr... Downloading C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd\CAEEBB 65D3C48E6DC73B49DC5063A2EE.ldr... Downloading C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd\F2D76D FAFD66C7F195F278417DF05888.ldr... Downloading C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd\F68262 4FFB08F6D955DBE7D9C0485084.ldr... Downloading C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd\FCB5C5 10AF7F09F313D9BDE85A707CC0.ldr... Downloading C:\Uni\Files\Nokia\BB5\Patch2\RAPIDOv11_2nd.fg... 7 important file downloaded sucessfully. Current filepack version: 7.60 installed. Current local executable version: 2.9.0.2733; Upgrading to latest version: 2.9.1.2751. Connecting to server: Main Receiving latest executable... MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
