Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 06-06-2007, 16:37   #1 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
what is the earse file i must use to earse 6280 without loosing PM erea????8mb or 16m
what is the earse file i must use to earse 6280 without loosing PM erea????8mb or 16m????????????
i need to know that asap
Old 06-06-2007, 21:58   #2 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
no one know something about that???????
i asked about this for more than one time but i did not get anything till now
this phone was alive but after receved some stuff on bluetooth it restarted and then go dead
it had 6.10 on it so i flash it with the same version but it is the same no chance
that why i need to earse it and reflash it >>> i allready read the certifecate from it to keep it for restoring but for pm i need to know which file to use becuase i do not want to loose the simlock info inside pm
Old 06-06-2007, 22:24   #3 (permalink)
BouRRi_GSM's Avatar
Member: 111457
why u don't backup full pm area
Old 06-07-2007, 00:07   #4 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
hi mate
just reflash ur phone again with the last vr
dont forget cnt
Old 06-07-2007, 07:08   #5 (permalink)
khawar's Avatar
Member: 51218
No need to do full earse,just flash MCU,PPM and CNT, the phone ll be alive again and also dont forget to full fomat after flash.
WBR KHAWAR
Old 06-07-2007, 10:35   #6 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
first how can i read full pm if the phone can not enter local mode??????
second i need to flash it with its same version and not higher one
any way i think even the supporter for this box does not know something about that
thank all
Old 06-07-2007, 20:10   #7 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
thank all
you r completely correct,some people just give idiot answers i really hate this box
Old 06-08-2007, 10:59   #8 (permalink)
Member: 285779
thank all
i face same problem , phone not turn to local mode ,, try manual switch to loacal mode THEN , TURN ON YOUR MOBILE , than phone will switch off than ur phone is local mode
sory english
Old 06-08-2007, 11:18   #9 (permalink)
alex12345's Avatar
Member: 152573
thank all
hi if u phone cant turn on local mode, it maybe u have downgrade the phone or cable. have u modify the cable to 68k and 7.5k??
with best regards
alex
Old 06-09-2007, 12:20   #10 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
indeed i need to know not only for this phone but for a lot of phones that can be repaired by doing this trick
last time i asked i got nothing so i did it my self it was E50 which was flashed with wrong version by someone and the phone is in white screen only and turn off so i do use earse file for 32mb from other box and then refalsh the phone and it was live again BUT:
i loose simlock info from it but i could keep the imie and cert so the phone work but locked
in case we can have earse file to each model to make it blank and then rewrite the version we need on it so we can fix many many phone by this way
and now when i ask for this information i got more good answer than what i expected like check your cable and so on
please and more please give me something i can use not only good idea OK
thank u for your care All of u
Old 06-09-2007, 12:25   #11 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
on ufs have read pm button then just click then save it for backup incase your unit have conflict regarding flashing you can use your backup.
Old 06-09-2007, 12:33   #12 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
really!?!?!
do u think that ufs can read PM of a dead phone with no local mode?!?!?!
big thank u
Old 06-09-2007, 12:35   #13 (permalink)
Member: 3900
@tsarkh
Phones that can't enter local mode or having a boot certificate problem on flashing using expensive boxes can be easily repair with "FREE" phoenix. I'm using Phoenix Service Software 2007.4.6.170 and it works like a charm...
Tested with 6280 that can't boot with other tools but successfully flashed with "USB Dead Flashing Option"....
Good luck....
Old 06-09-2007, 12:43   #14 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
really!?!?!
big thank u
sorry bro, i didnt read that your phone is already dead, ufs cant read pm if your phone is alredy dead, try to full flash your phone to make your phone alive again.
Old 06-11-2007, 11:29   #15 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
i am waiting for amoe info from our box supporter ...
What is the problem? fun MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 15:48
What is the TA file for GDFS repair for C902? dune2 SETool2 0 11-17-2009 05:26
what is the price in india. and where to buy this box sunny_luthras Cyclonebox 2 05-06-2009 11:19
What is the problem with smti server,i loose credit without phone done segun4u SMTi 9 09-16-2008 15:11
what is the flex files for ? mccm Smart-Clip 2 02-23-2008 07:20
Page generated in 0.35565 seconds with 11 queries
