Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dct4Direct
Dct4Direct Solution Under Testing By forum Admins
Old 07-02-2005, 00:06   #1 (permalink)
Member: 54406
Thumbs down Caution!!! Dtc4 No Signal !! After Change The Imei
HELLO!
DEAR
POSTING'S I HAVE A LOT O NOKIA 3100B WITHOUT SIGNAL AFTER CHANGE THE IMEI
I TINK THAT IT IS A BOX PROBLEM!!!
BAD SUPPORT!!!!
PLEASE DTC4 EXPLAIN WHY??
Old 07-02-2005, 00:49   #2 (permalink)
Don carlo's Avatar
Member: 134684
hi
explain more pls
Old 07-02-2005, 02:16   #3 (permalink)
Member: 54406
oki
it's i s very easy
after change the imei the phone not signal
why ???
Old 07-02-2005, 03:41   #4 (permalink)
Don carlo's Avatar
Member: 134684
hi
hehe,if that is easy
then contact your resseller and told him that.
strange but that is not CDMA phone that can need prl.
B.R
Old 07-05-2005, 15:59   #5 (permalink)
Member: 54406
imie !!
i change the imei for a nokia 3100b but it is not signal after change the imei
Old 07-05-2005, 16:02   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
because 3100b Will not work in 900 MHz
Old 07-05-2005, 19:02   #7 (permalink)
Member: 151529
Old 07-10-2005, 09:00   #8 (permalink)
Member: 2413
no network
the same problems on a couple of 9500...
Old 07-10-2005, 23:41   #9 (permalink)
Member: 54406
I Probe It
In 850 Mhz An It Don't Have Signal Y Have A Lot Of Phones With This Problem
Regards
Old 07-11-2005, 03:06   #10 (permalink)
Don carlo's Avatar
Member: 134684
Regards
hi again
LOL
the best way to do is to scheck your brain
with u is somthing wrrong
B.R
Old 07-11-2005, 03:09   #11 (permalink)
Don carlo's Avatar
Member: 134684
can you give us more info, detail,.... about the probleme
B.R
Old 07-12-2005, 07:41   #12 (permalink)
Member: 2413
no network
simply after having changed imei phone has not network anymore...
BR.......Luigi
Old 07-12-2005, 09:16   #13 (permalink)
Don carlo's Avatar
Member: 134684
BR.......Luigi
is that so simply ???
i think is never so easy like u say
all attention amigo
but try pls to thinking little about this probleme before u say here (simply)
did u have experience with flashing NK 9500?
B.R
Old 07-12-2005, 12:49   #14 (permalink)
Member: 2413
9500 flashing...
if i say i faced this problem please don't ask me about how or what i used to flash 9500...since here we are using a DCT4 direct Imei changing not flashing device .Just check yourself using a 9500 and if you get it working please help me to sort it out.I'm simply reporting a problems i have with 9500.That'all !
Regards...Luigi
Old 07-12-2005, 18:23   #15 (permalink)
Don carlo's Avatar
Member: 134684
Regards...Luigi
hi
DCT4 Direct was tested with all models and NK 9500 was done by dct4
without any probleme
i can only say flashing procedure was fault
B.R
1112 no signals after change imei? smarty3399 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 01-19-2010 12:25
j100i no signal after change language ! ticoichip Infinity-Box 3 03-30-2008 11:43
5140 no signal after changed flash ic krdzo Nokia Hardware & Hardware-Repair Area 0 08-16-2006 14:08
3650 no signal after change cpu nimanima Nokia Hardware & Hardware-Repair Area 1 04-29-2006 11:41
7710 no signal after change imei venizmobile Dct4Direct 2 11-05-2005 23:03
Page generated in 0.59628 seconds with 11 queries
