Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dct4Direct
Dct4Direct Solution Under Testing By forum Admins
Old 06-14-2005, 08:42   #1 (permalink)
Member: 12869
dct4 direct don't want to write
Sorry, if I'm posting this in the wrong section, but I frustrated.
I bought the dct4 direct from i-phone for $599.00, it came with no manual, and no charger, that's fine. Got the manual from the dct4 direct site and also the update, so the box is working fine. The problem now, is that the software will not write imei, I can read the info when I press "check" but it does allow me to write, can someone tell what the problem is, or what it is I'm doing wrong.
I've e-mailed the i-phone support team twice already but still waiting for their reply, the sales reply is quick but supported reply is f**king slow. I've even called them but only sales have phone support you have to e-mail no phone number so I'm really angry 'cos I need to make my money asap.
Old 06-14-2005, 09:54   #2 (permalink)
Member: 151529
if the "write" button is not enabled, then your phone hasn't the correct firmware version or it isn't supported at all. you can check supported modells and versions in file "SupportedModels.txt". this file should be in the same folder as the .exe file.
e.g:
DCT4 Direct V 1.32
Supported DCT4 phones for this release:
NHM-7 - 8310, v 6.20
if you have a NHM-7 phone (8310) that has another Firmware than v6.20 then you need to flash the phone to the correct version(MCU and PPM).
After that the write button will be enabled and you can proceed with the "write" operation.
Old 06-14-2005, 12:49   #3 (permalink)
stallone1®'s Avatar
Member: 57374
Sonork: 100.41718
hi ,
we never receive any email from you so please if u have support question pls go and create a ticket to avoid lose email
Dear Sir,
For support email you need to login to www.i-phone.org and then scroll down and click the CONTACT US and create a TICKET .Thank you
Regards
I-Phone Support Team
www.i-phone.org
Old 06-14-2005, 13:15   #4 (permalink)
Member: 12869
Thanks alot dct4direct, its ok now.
As for stallone1®, why don't you have a direct phone number to your support team, but have to sales team, for sure you must receive and much calls for sales as for support as well, 'cos i called three times but got put through to sales team and not support WHY????????????????????
Old 06-14-2005, 20:17   #5 (permalink)
stallone1®'s Avatar
Member: 57374
Sonork: 100.41718
the support i can explain we have few hundred email daily for support team to reply so if we receive call for support do think how many person i-phone have to hire we ar not big company like mircosoft even mircosoft dont have this service too if u dont know how to use window xp or 98 and dont even have a email support worst
at least 50person have to hire to recieve all the call for support so maybe if we sell the dct 4 direct at usd 999 instead of usd 599 so maybe we can afford to hire all the 50 people ....so we have give email support i dont think this is not good enough
correct me if i am wrong
Old 06-16-2005, 15:17   #6 (permalink)
Member: 1169
Trying to init comm...Done.
Entering flash mode...Done.
Erasing device area...Done.
Write firmware area...Done.
Restore orig values...Done.
Restarting the ASIC...Error: 0x0A00
nhm-7 ver 6.20
getting this error 4 times out of 5
any ideas
Old 06-16-2005, 15:47   #7 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
mate that happens to me everytime just about, 9 times out of ten i dont even get as far as restarting the asic before it errors....i have to keep pressing the power button on phone
oh, and if it does error at restarting asic, you can unlock the phone using griffin/twister/ufs etc etc and everything will be ok, tested by me
Old 06-16-2005, 16:20   #8 (permalink)
Member: 153560
hi
what version of the soft are you using ?
it is better to post full information regarding your problem, then im sure you will get some response.
Dolph
Old 06-16-2005, 17:01   #9 (permalink)
Member: 8879
Sonork: 100.84016
ok dolph next time i get a phone in to do i will screen shot evey thing i do just to show you how much grief im having, as for asking reseller, my reseller was a uk 1, and imei changing is a bit of a dak area here, and anyway, all the boxes he's used have worked ok.....
Old 06-16-2005, 19:43   #10 (permalink)
Member: 1169
Cheers James, will give that a go tomorrow
Old 06-16-2005, 19:47   #11 (permalink)
Member: 8879
Sonork: 100.84016
no problem
regs
Jay
Old 06-17-2005, 12:38   #12 (permalink)
Member: 1169
unsure on how do do this jay as after the rebooting asic i get a dead phone, so the phone will not switch into flash mode to unlock it.
reflashing the phone with the original flash gets the phone working again but the same problem once dct4 direct partial flashes it again.
Old 06-17-2005, 13:12   #13 (permalink)
Member: 153560
in the new beta version 1.35 you can still write to a dead phone, also which cables are you using ? auto ignition is best,could be a HW problem maybe the regulator, best to get your contact to check it for you,
Dolph
Old 06-17-2005, 14:08   #14 (permalink)
Don carlo's Avatar
Member: 134684
after my experience i have get the first time also many problemes with error ect,....
and i have try many possibelity to get my box full working .
conclusion ,
that was PC probleme
-The best what we can do is to use dct 4 direct without twister inside the systeme.
That was the phone
-many phones have also board probleme and will dont accept the patch:
conclusion :i have change the board and after this procedure working and accept without any probleme the patching
That was the box
-with the old version if i will patch Nk 3100b i get allway error by asic restarting by 85% ,after that i scheck the imei Nr and that show me Nr change it without SPC procedure, connect to another pc the phone and unlock it with UFS,
phone working....................
and and .........
B.R
Don carlo
Old 06-17-2005, 14:43   #15 (permalink)
MELDON BA's Avatar
Member: 65015
its really hard to use new untested boxes, keep it up beta testers. so authors can fix the bugs asap.
Iphone 3GS 3.1.2 stuck don't want to go to 3.1.3 Kais_Unlocker iPhone ,iPod & iPad (Apple Inc. Products) 3 03-27-2010 02:37
Quotes wanted for N95 repair. Don't want to pay Nokia! Arcticmatt Job Opportunities / Vacancies 0 01-06-2009 21:17
My DCT4 Direct don't work. danidelta Dct4Direct 11 07-02-2005 03:53
i don't want to make an advertisement.... spawoolm Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-20-2001 00:11
Page generated in 1.22299 seconds with 11 queries
