Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Dct4Direct Solution Under Testing By forum Admins |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2002 Age: 33
Member: 12242 Status: Offline Thanks: 4
| LOCAL MODE Failed Hi all, I got a problem to go in Local Mode, its impossible to go there, i using UFS cables. I tested on 3 different phones same result. Can someone confirm me cable to use or give me any cable sheme Thx in advence |
| The Following User Says Thank You to ZerGoS For This Useful Post: |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002 Age: 37
Member: 8879 Status: Offline Sonork: 100.84016 Thanks: 22
| hi mate, can u be a little more specific please? what model was it you were trying? |
| The Following User Says Thank You to .:GSM International:. For This Useful Post: |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2003 Location: egypt,alexandria,(nassimgroup team) Age: 37
Member: 31018 Status: Offline Thanks: 0
| mate you use ufs cable withu ufs box each phone has its cable use true cable detect if it is dct3 dct4 wd2 (check) (info) then (int locks) all will be ok if your phone serial ????????????? for get it it is hardware probleme hope that i gave you all info mns_23 br |
| The Following User Says Thank You to Slider_Gsm For This Useful Post: |
| | #4 (permalink) |
| Thx for reply, tested with 6100, 3100, 3200, 8310, 6600 with this phones its impossible to Check, and Power half of all this go in Test Mode, i dont know if its good mode or not (with UFS its go in Local Mode) I tested software on XP SP2 and XP Pro SP2, last version and previous. Reading with UFS 100% OK, but with DCT4 Direct, i only go Errors : - Restarting power . . . Error 2! - Restarting power . . . Error 2! Request not accepted ! - Checking phone . . . Request not accepted! - Checking phone . . . Request not accepted! Error 3! and also Green Light stay powered (on Power failed) BR, |
| | #5 (permalink) |
| are someone able to tell me if the problem is the box or computeurs cables... from today morning i fight with software and nothing |
| | #6 (permalink) |
| ok, firstly the curent version doesnt support the 6600, thats asic 5.... if the cables work 100% with ufs ok and you have tried everything we spoke of before, then i would say POSSIBLE box error...keep trying though, cos even with 0x003 errors etc etc the box will eventually work ok! Also, ty holding the cable hard in the back of the phone, try pressing power button during functions, or even maybe try to connect charger to phone throughout duration of process! You said that u had tried it on 3pc's, well try and format 1 of them with xp pro sp2 and make sure that dct4direct is the ONLY thing u run on that pc, i feel it has a conflict somewhere, but dont know where, so try a fresh machine, also, what processor are you running? I know that some softwares dont run vey well on 64bit machines, maybe this could also be the problem....do9wnload the latest vesion of software and run it again, possible corupted software...if all that fails, then im sorry, i have no ideas left...at the moment anyway.. ooh, 1 last idea, when you first press check or whatever you press first, press it THEN connect phone to cable....maybe a boot form the box will help it along thats all i got Regards |
| | #7 (permalink) | |
| Junior Member ![]() ![]() Join Date: Jun 2005 Age: 35
Member: 151529 Status: Offline Thanks: 0
| Quote:
this is a box HW Problem, it is the power regulator, it needs to be changed, contact your reseller, i beleive it is ST KF33 500Ma you need to replace it with. br dct4direct | |
| The Following User Says Thank You to dct4direct For This Useful Post: |
| | #8 (permalink) |
| Thx for reply, Tomorw i will test i will receive new ST KF33BD, i will change i let you know about result. BR |
| | #9 (permalink) |
| Hi, I allready changed the KF33BD, and the box work fine, i did 8310, but i have problem to do 3100 - Entering Flash Mode. . . Error : 0x233 BR |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia 2600 (RH-59) Init local mode Failed | GRIFFFMAN | UFS2 + UFS3-Tornadoflasher | 15 | 10-24-2010 05:16 |
| 2600 local mode failed | jimmy indra | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 02-09-2006 20:51 |
| local mode failed | jprakash | NEC | 2 | 01-28-2006 12:38 |
| Nokia 6670 - Init Local Mode Failed | Hersonsky | Twisterflasher | 1 | 11-13-2005 10:34 |
