Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Dct4Direct
Dct4Direct Solution Under Testing By forum Admins
Old 09-14-2005, 16:16   #1 (permalink)
Member: 180623
Nokia 3100 not charging
hello, i have got a nokia 3100 that displays "not charging" whenever i try to chargre it...can anybody pls help me with a solution...thnx!
The Following 4 Users Say Thank You to a2jo For This Useful Post:
Old 09-14-2005, 17:02   #2 (permalink)
mamin's Avatar
Member: 32796
First try to use diferent chargers... that message means : phone recognize charger but dont allow charging...
After that if 100% sure that no problem in charger, try flash it...
Old 09-15-2005, 10:11   #3 (permalink)
Member: 180623
Thanx, i will try that soln and come back to you....
Old 09-15-2005, 10:45   #4 (permalink)
Member: 180623
Tried a different charger but still no success....
Old 09-16-2005, 14:25   #5 (permalink)
Member: 179713
open phone and clean point of contact under connector. Else you must solder resistants near connector.
The Following User Says Thank You to bosseq For This Useful Post:
Old 09-17-2005, 14:28   #6 (permalink)
Member: 126492
try charger without batt, check voltage in conbatt, if low voltage (- 3 volt ) change UEM and rebuilt IMEI
Old 09-17-2005, 15:03   #7 (permalink)
Member: 180623
Hi, thnx...I have tried the cahrger without bett, and the voltage at the bett contct is ok...3.6V...any further suspect?
Old 10-13-2005, 14:40   #8 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Try to flash mcu+ucp+pm and it will ok otherwithe replace uem
Old 11-20-2006, 10:15   #9 (permalink)
Member: 194890
reflow smt components
Try use hot air and reflow all smt components from uem below.
Old 12-10-2006, 17:15   #10 (permalink)
Member: 281925
Sonork: 100.113915
uper side battery conactor in center 2 PF or Rajistance change this is parmanant solution
The Following User Says Thank You to shripalkawdia For This Useful Post:
Old 10-24-2009, 05:39   #11 (permalink)
Member: 1148196
Sonork: shafqat
nokia 3100
nokia 3100 not charging diagrame
How to repair nokia 3100 not charge with mt-box? deann MT-BOX 0 03-25-2010 11:12
Help Nokia 3100 not charging a2jo Nokia Hardware & Hardware-Repair Area 8 08-08-2006 10:50
3100 not charging with a nokia ACP-12E charger hooi76 Nokia Hardware & Hardware-Repair Area 3 04-21-2006 13:56
nokia 3100 not charging Gsm Lab Nokia Hardware & Hardware-Repair Area 4 03-31-2005 16:07
Nokia 3100 not charging Microemission Nokia Hardware & Hardware-Repair Area 4 03-09-2005 15:13
Page generated in 0.88399 seconds with 11 queries
