Auto Ignition Cable Schematic @ SST-GSM My friend and i is trying to make the Auto Ignition Cable using the schematic on your support site but we are having one problem: "on pin7 of the ufs is nothing where you could draw a voltage from". Please explain this. Or is it a mistake? Thanks |
Also C62 unlock program, why cnat use with ufsx box ? |
I'm AWAITING YOUR REPLY @ SST-GSM My friend and i is trying to make the Auto Ignition Cable using the schematic on your support site but we are having one problem: "on pin7 of the ufs is nothing where you could draw a voltage from". Please explain this. Or is it a mistake? Thanks |
Make sure that you cownt from the correct side. The pinout is for 8 pins ufs connector only. If your connector is different (with 10 pins for example) or you still have any dificulties in this ,please contact to [email protected] |
OK, WE'LL work on it later. thanks |
