Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: Ukraine Age: 33
Member: 7575 Status: Offline Thanks: 6
| Bootcore Repair for EL71/S68/C81 EL71 FlashID: 0089,887E if rewrite bootcore from fullflash, it's cann't be solved by unlock, repair, etc (otp-bootcore imei mismatch)... |
| | #3 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003
Member: 38795 Status: Offline Thanks: 0
| Quote:
This is not SST fault as it rewrites the file you select and by default bootcore area is skipped during flashing.At the posted data from this and another topic we can see that you post data read from another program instead of SST Anyway there are some files you can upload to the phone to solve this problem. Please contact to our support email for further instructions. | |
| | #7 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: In Your Room Age: 36
Member: 97299 Status: Offline Thanks: 18
| i have the same problem bootcore destroyed with papua i have trayed with sst 7.55 with full flash repair unlock etc but no chance phone do not start no beep nothing any ideea how to repair bootcore ? |
| | #9 (permalink) | |
| Quote:
p.s. that it's the info first full flashed with just boorcore recovery after tested just beep then repair test = just beep Phone model changed to: S68/C81/EL71 Please connect the needle to Test-point Starting Repairing Procedure ... Flash Chip: 0089887E (Intel) Bootcore IMEI: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ OTP IMEI: 358941002861808 Writing Simlock ... Phone Successfully Repaired then unlock after tested =just beep Please connect the needle to Test-point Starting Unlock Procedure ... OTP IMEI: 35894100286180 EEPROM IMEI: 358941002861808 Writing Simlock ... Phone Successfully Unlocked and that it's the phone info Please connect the needle to Test-point Flash Chip : 0089887E (Intel) Bootcore IMEI ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ FIRMWARE PHONE MODEL: EL71 FIRMWARE VERSION: 06 LANGUAGE GROUP: lg3 | |
| | #10 (permalink) | |
| Quote:
It is posible that this firmware version does not support new flash chips like 00089887e that were available in later versions | |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: TuNiSiA Age: 32
Member: 111457 Status: Offline Thanks: 466
| first full flash EL71_v6_lg3_full.bin have bcore from S68 the second full flash EL71_v31_lg3_full.bin have Bcore clean so these 2 Full Flash are from not working phone when u will upload good working File ??? |
| | #13 (permalink) | |
| Quote:
Please use bootcore recovery feature! Please uncheck firmware area only checkbox when you want to upload repair flash. | |
| | #14 (permalink) |
| thx for answer but what's this mean This is Working phone : Flash Chip : 00208819 (ST) Bootcore IMEI ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ FIRMWARE PHONE MODEL: EL71 FIRMWARE VERSION: 31 LANGUAGE GROUP: lg35 This is dead phone just beep : Flash Chip : 0089887E (Intel) Bootcore IMEI ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ FIRMWARE PHONE MODEL: EL71 FIRMWARE VERSION: 06 LANGUAGE GROUP: lg3 |
| | #15 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 36
Member: 135671 Status: Offline Thanks: 387
| The same me problem Flash Chip : 0089887E (Intel) Bootcore IMEI ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ FIRMWARE PHONE MODEL: EL71 FIRMWARE VERSION: 06 LANGUAGE GROUP: lg3 What solution to do repair with phone ??? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SST 7.61 -fixed repairing procedure for S68/C81/EL71/E71 | SST-GSM | SST-Dongle | 25 | 11-25-2008 17:14 |
| CAn you add new SIEMENS file to support for SL75, S68, EL71, M81, ME81 and other new? | wgmmmx | MT-BOX | 0 | 10-21-2007 16:45 |
| EL71 or C81 or M81 Baseband Firmware | ururk | x6x and x7x Flashpatching | 0 | 07-20-2007 18:31 |
| S68/EL71/E71/C81 cables help | Nurettin Duman | SST-Dongle | 5 | 06-12-2007 16:19 |
| New SST v7.56 - Added Support for S68/EL71/E71/C81 with ST 208819 flash chip | XisiX | SST-Dongle | 3 | 11-19-2006 06:52 |
