Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SST-Dongle
Old 01-28-2015, 15:56   #1 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
Post Data Recovery from bricked/dead phones with SST Android Suite v5.1.3
Data recovery from dead phones with Qualcomm chipset using 1 wire test-point
Android Phones with Qualcomm chipset have a special factory service mode which can be activated by 1-wire test point method. The test point location may vary in deferent CPU configuration. In some phones the test point needle is connected to Dat2 eMMC interface line (4 bit eMMC mode and MBR GPT signature check back door).
1. Connect SST BoxOne black needle or connect the test point to GND. After the phone is in factory service mode a new device will be detected in device manager as SST Test Mode. The device may be also detected as HS-USB QDLoader 9008
2. Remove the needle from the test point press Read button in SST_LGQC. For 7x27A based LG models you can directly read android data partition.
3. Saved Data image file can be mounted, browsed or used as a recovery source in SST Android Suite.Saved full flash image file you can be used as a recovery source in SST Android Suite.
Warning the current version of SST_LGQC supports only Qualcomm Snapdragon S1 (MSM7x27A chipset)! Other Qualcomm devices may be added if requested by our SST Dongle users.
Data recovery from dead phones using direct eMMC Reader
Data recovery from dead phones using USB to eMMC Socket adapter or SD to eMMC Socket adapter
(example)
These are third party devices available on the market. They offer full support of eMMC specification. These devices can read eMMC if it is desoldered and put in the socket or if you solder wires from eMMC to the supplied interface header.
Data recovery from dead phones using DIY USB to eMMC adapter
(disassembled low cost USB to micro SD card reader)
(schematic diagram SD to eMMC converter example)
A direct eMMC Reader device consist of SD Card USB Mass Storage Device Controller, level shifter and voltage regulator for eMMC power supply. The interface lines can be directly soldered to PCB. The eMMC interface may have 1, 4 or 8 DATA lines whereas SD Card uses 1 or 4 Data lines.SD Card USB Mass Controller used for direct eMMC Card reader should not use the legacy SPI mode instead of the 1 or 4 bit bi-directional mode. Direct eMMC Reader can be easily build from low cost USB SD/micro SD Card reader like the one on picture above and level shifter based on auto bi-directional level traslator IC like TXS206, MAX13030E, TXS2612 , ST2149 and etc. A design sample is provided in the manual. Direct DIY USB to eMMC adapter may have 1 or 4 Data lines.
For all direct eMMC readers please follow instructions like in Android File Recovery for USB Mass Storage Device.
Data recoveries from dead phones using 3rd party software file backup
Plain binary format backup from 3rd party software is supported as input source for recovery in SST Android Suite. Please read details in the manual
The Following 3 Users Say Thank You to SST-GSM For This Useful Post:
Old 01-29-2015, 00:25   #2 (permalink)
Member: 732994
Thanks Meter: 81
Nice to see you again
Old 02-17-2015, 03:56   #3 (permalink)
Member: 102076
Thanks Meter: 41
nice to meet you,, who is your reseller in phillipines.
Old 02-19-2015, 10:01   #4 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
Unfortunately no reseller in Philippines.
Old 02-19-2015, 12:46   #5 (permalink)
Member: 937338
Sonork: 100.1651155
Thanks Meter: 114
sir where buy in india
Old 02-19-2015, 15:01   #6 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
SST Dongle for SST Service Toolbox for Siemens BenQ-Siemens phones can be used for SST Android Suite and there is no activation needed.
Bellow are SST Dongle resellers in India from our old records.
Please note that all info may be outdated or there could be no stock.
GSMMUNNA
India
GSM: +91 981 861 6129
ICQ: 192305872
E-mail: [email protected]
Mobileclinic
New Delhi, India
GSM: +91-9811158555
ICQ: 146946267
Honey
India, New Delhi
GSM: +919811615306
ICQ: 201958478
Web Page: www.mobilemasters.org
Page generated in 0.15059 seconds with 8 queries
