10-05-2005, 18:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Croatia Age: 48
Member: 14602 Status: Offline Thanks Meter: 18 | dead c65 after unlock with SST help... i got one c65 which i try to unlock with sst and after is dead when i try again he said bad eeprom... i try repair funktion but nothng what now? i don't know which sw is... |
10-05-2005, 19:53 | #3 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: BiH Age: 49
Member: 46341 Status: Offline Thanks Meter: 15 | Quote:
ciling phones yust by unlock function!? | |
10-06-2005, 13:45 | #5 (permalink) | |
No Life Poster Join Date: Sep 2003
Member: 38795 Status: Offline Thanks Meter: 106 | Quote:
Please report us what exactly you did. Have you used a test point? Do you press unlock only or you 've also tried to flash the phone? Did you used a fully charged battery? What flash id is displayed on Read Info function? Is the correct imei displayed on read info function? Is it the same imei as the one at athe back label? | |
10-06-2005, 18:47 | #6 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | yes i used test point exactly to manual,i press only unlock i didn't try to flash phone i used full battery flash id intel 0089880D imei 354763008425626 it's the same imei if u want i can sent to you bad eprom so u can calculate it or something else. what to i do? can i flash it? is it important which sw is phone.... |
10-06-2005, 18:48 | #7 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | my emali is [email protected] |
10-07-2005, 11:10 | #9 (permalink) | |
You can also flash the phone with the repair file from our support page. C65 phone are supported already more than 1 year. | |
10-10-2005, 18:45 | #10 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: kumasi Age: 46
Member: 16077 Status: Offline Thanks Meter: 0 | Quote:
i have flash it with CX65_v16_lg3.rar after flash/repair soft does not give bad eeprom message anymore but phone is still dead need urgent help please | |
10-10-2005, 21:36 | #11 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | try this....u must fix the boot core on your phone .Read block 00-02 from your phone and save it in a directory 2.Download http://www.sst-gsm.com/scard/X65_fixbootcore.zip from sst support area 3. Run the program and enter the original Imei of the phone (the one is written at the back side of the phone) 4.Press the button select the file and then upload the block 00-02 using block write of SST 5.Now after pressing "Repair" button your phone should be alive |
10-11-2005, 15:42 | #12 (permalink) | |
Siemens S56 dead after unlocked with sst | godwin | E-Gold Based Phones | 2 | 07-21-2009 19:24 |
CF62 indicates WRONG SOFTWARE after unlocking with SST | gancellshop | Siemens Hardware Repair Area | 7 | 06-17-2006 03:56 |
dead c75 after unlock with sst | mmanduri | SST-Dongle | 4 | 12-20-2005 00:55 |
C65 dead after unlocking with sst 5.31 | rachelyna | S-Gold Based Phones | 9 | 05-05-2005 17:08 |
C6v vers 15 DEAD AFTER UNLOCK WITH SST 532 | codec_romania | S-Gold Based Phones | 7 | 01-14-2005 13:47 |
