Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SST-Dongle
Old 12-30-2006, 07:19   #1 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
0089887E (Intel) EL71
Flash Chip : 0089887E (Intel)
Bootcore IMEI яяяяяяяяяяяяяяя
FIRMWARE PHONE MODEL: EL71
FIRMWARE VERSION: 06
LANGUAGE GROUP: ises
how repair this phone
Old 12-30-2006, 17:58   #2 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
as i see ur phone is already flashed with EL71 V06 from support area??
tell me if i'm wrong
Old 12-31-2006, 06:02   #3 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
yes
Old 12-31-2006, 14:27   #4 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
the Flash file EL71 v06 is support area is ok, but if u flash ur phone with it, and SST, it will not work (as u see no LG detected)
if Bootcore is ok (first 256Ko), Flash ur phone with V_Klay then do repair with SST, and phone will work
anyway
read first 256Ko of Flash or Fubu and send to me, i will try to help u
Old 01-01-2007, 15:39   #5 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
just use recovrey and do repair and all will be ok
Old 01-01-2007, 21:24   #6 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
recovery with SST is the bootcore killer with these new model EL71, S68...
becarefull
i have a lot of EL71 and i test all siemens box, and at this moment u will never succes repair completely dead (eeprom+bcore) of EL71 with any siemens box, but i can repair and help u
Old 01-02-2007, 11:22   #7 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
becarefull
Repair with bootcore recovery will fully repair the bootcore area.
Make sure that you use fullflash for the same flash chip.As I see the flash chip is the new 0089887E so the full should be for the same flash chip.
Old 01-02-2007, 12:46   #8 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
0089887E is intel chip
Flash file EL71_v6_lg3_full.rar from support area is for 0089887E intel chip
i tested it and it's ok but with other tool
i have also ST chip working Flash File
Old 01-02-2007, 13:02   #9 (permalink)
yui
yui's Avatar
Member: 7528
Thanks Meter: 40
other flash files not work from support ??!!!
but after write full backup with vklay phone work good!!
Old 01-02-2007, 17:29   #10 (permalink)
XisiX's Avatar
Member: 37090
Thanks Meter: 42
You promissed beter support regarding flash files long time ago, still nothing
Old 01-03-2007, 10:44   #11 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
unlocker must help supporter with reading Fubu and send to us
i will upload 2 working files, 1 for ST chip and another for intel chip
Old 01-18-2007, 03:12   #12 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
And when you do this becouse I have 1 phone hang on startup and before this hang when I use it. And I can't find good working flash files maybe you tell me where to find to write to phone and will phone work ok ?? ?? Maybe bootcore is bad and this is my problem ?? ??I wait for help bye
Old 01-31-2007, 08:42   #13 (permalink)
Registered User
Member: 64168
Thanks Meter: 3
sst kiled my el71
chip is 0089887E (Intel) and try recover bcore,flash and no result - allweys YYYYYYYYYYY.
help SSt
What about EL71 and EF81? Impossible to unlock? James_S NON Siemens Brand (ODM Phones) 6 06-04-2007 20:20
EL71 simlock Axe Man S-Gold Based Phones 68 11-15-2006 13:51
BENQ EL71 unlock ??? sidcho DreamBox 3 08-23-2006 14:54
BenqSiemens EL71 gsmCroatia Siemens Hardware Repair Area 1 08-03-2006 11:25
Benq Sİemmens El71 Unlock Help cenk kamil x6x and x7x Flashpatching 0 07-04-2006 15:19
Page generated in 0.25811 seconds with 9 queries
