Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SST-Dongle
Old 12-29-2005, 07:29   #16 (permalink)
gecata's Avatar
Member: 16994
Thanks Meter: 157
@Sioma Man, before make a full flash with flash from sst support area unchek "Protect bootcore area". Make flash phone and write repair eeprom for 4MB flash from hallo. Phone must be alive agai. Tested tonigh with 4 dead phones.
P.S. If You wont to change language just get proper file from sst support site and just flash it.
Good luck!
Old 12-30-2005, 20:38   #17 (permalink)
Member: 16237
Thanks Meter: 30
Thanks man
Phone alive again,i already forgot about unchek,i already have before this problem with ax75
Old 12-30-2005, 20:46   #18 (permalink)
Member: 1778
It's not good idea to change bootcore area. Phone becomes unstable and deadable. But who cares.
There is much beter way to "undead" these phones, but this is for experts only.
Happy New Year!
Old 01-28-2006, 02:12   #19 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
Originally Posted by hallo
...are that special flash? Is thes one v14 AMD 4Mb? I just try to repair one A70 v32 with 4Mb Flash IC and gess what......he is steel dead!!!!!!!
Do You have more explanation or me to use Joker to fix these phone?
Thank's in advice
btw....after try to unlock A70V32 4Mb Flash IC with SST 6.83 I gat Wrong Softweare???????
same thing apllied to me, after unlock. wrong software. aster repair. dead, after flash. mortuary.
this apply to every of this version.
i suggest vergin or unlocked eeprom of all phones uploaded to sst support so to avoid buying phone for custumers
Old 01-28-2006, 09:58   #20 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 92
It's true but...
..problem is solved couple days after that post..."..I forgot to say that my A&) is working again and it was bug in 6.83 wich kill hem and make all of these thing like I alredy describe above.
So for anybody who may have the problem like I did solution is to write these eeprom to phone and phone is a live again(big thank's go's to DeDaMraz!!!)......"...
Yes...stilll some A70 get WrongSW after unlocking with SST even 6.85, but U can solve these...no voris....
p.s. For every problem with not powering on....most propobly it's TP problem..
Cheers
Old 01-30-2006, 18:16   #21 (permalink)
ppl
ppl's Avatar
Member: 7069
Thanks Meter: 6
Yup the true here is cause Hallo fineshed sst dirty job. E2P have ****in difference between 8MB and 4MB based headset.So all of SST Team mus say a BIG THANK`S to member Hallo.They wrote for this problem before 4-5 mount`s but in our market here in Bulgaria have no to this momment 4MB flash IC based headset`s
Old 02-01-2006, 02:07   #22 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
And How Was Hallo's Problem Solved? Give Details Pls
Old 02-01-2006, 09:46   #23 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 92
@magixian....
..are You read about on first page of these thread? Pl's go to first page and read....if You don't undarstan pl's let me now and I try to explane to You more detailed. OK?
Cheers
Old 02-03-2006, 02:04   #24 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
ok, it is now clearly understood!
Old 02-03-2006, 02:05   #25 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
ax 75 repair eeprom?
Old 02-06-2006, 11:20   #26 (permalink)
Member: 74155
A70!!! Thanks Hallo!!!
I had 2 phones dead, 1 unlocking... and the other triyng to change the language!
I did like HALLO say, and they are working again!
Thx again!!!
Old 02-06-2006, 14:24   #27 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 92
I'm glad to see...
Thx again!!!
...but like allredy told....regards goes to @DeDaMraz who give that repair eeprom....I just poot here becose @SST didn't poot to support area.
Cheers
Old 03-02-2006, 16:24   #28 (permalink)
Member: 231660
I have a siemens a57 when i powered it it was just blue lighting for few second then off i cut the test point and flash with A57 v3 lq3 repair fullflash by sst after flash it show me bad comunication. And if i power on the keypad light on & off (just blip) and nothing Else. What i can pls help me. NB: I flash it with direct cable. Pls help
Old 03-02-2006, 16:28   #29 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
For A57 with Micron Flash chips you should check "repair 2Cxxxx" on SST v 6.86 and it will repair the eeprom area
Old 03-08-2006, 03:18   #30 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
Thx again!!!
4 ME NEVER WORKED, PHONE IS STILL DEAD, VERY DEAD!
A70 v32 After full flash, not power on. microtel E-Gold Based Phones 12 12-01-2005 12:20
Need flash from T68 with STM Flash Chip (ARM) merwin Sony Ericsson 8 05-14-2004 17:45
PLEASE HELP-UNLOCKING of C35 with new Flash chip inside!!! Joseph x1x to x45/x50 3 02-06-2001 09:35
Page generated in 0.27886 seconds with 10 queries
