-   SST-Dongle (http://forum.gsmhosting.com/vbb/f310/)
-   -   Please Read about A70 v32 with 4MB flash chip (http://forum.gsmhosting.com/vbb/f310/please-read-about-a70-v32-4mb-flash-chip-250092/)
SST-GSM 11-23-2005 08:57
There are some A70 v32 with 4MB AMD flash chips. It is not possible to upload 8MB fullflashes or flash with earlier version of winswup.
For fullflashing of these phones please use our special file for 4MB AMD flash chips
AssenBG 11-27-2005 22:12
I think it's better to use WinSWUP to revive any Siemens EGold/SGold phones. It's easy and every time 100% success.
For BG users of SST we can open ER for dead phones.
For more info mail private.
hallo 12-01-2005 18:38
So mr.SST where...
...are that special flash? Is thes one v14 AMD 4Mb? I just try to repair one A70 v32 with 4Mb Flash IC and gess what......he is steel dead!!!!!!!
Do You have more explanation or me to use Joker to fix these phone?
Thank's in advice:confused:
btw....after try to unlock A70V32 4Mb Flash IC with SST 6.83 I gat Wrong Softweare???????
SST-GSM 12-02-2005 10:07
If you get Wrong Software after any procedure it is cause by a problem either in the cable or in the eeprom itself. In this case upload one of the eeprom from the support page and it will fix the problem.If the phone is not powering after eeprom _type1, just upload eeprom type2. you can also upload 4MB special flash or if you have sst v6.84 any from the other flash files and if the phone is not powering after the executed repairing procedure upload one of the eeprom files from the support area whith which the phone will power on.
hallo 12-02-2005 10:35
OK...these is support what I looking for...I gona try and let You all now what is going on. One more thing....I gat WrongSw only on A70v32FlashIC4Mb and not on A70v32FlashIC8Mb(I have to do a couple of them here at the same time...) with 6.83...I just instal 6.84 and I'm gona try to repair my phone..:confused:
hallo 12-02-2005 10:44
And...
..now flashinfg bar goes to 100%, after that writing Eeprom goes fine, Repair buton makes hes job, Unlock buton makes hes job....but result is the same evry time...phone is dead..just a very low tone from phone when I try to power hem on...
Phone was a new, TP I check again using microscope...everything is OK around TP and a same TP is cuted right..
Is that do something to You mr.SST:
FlashChip: 0001227E(AMD):confused:
hallo 12-02-2005 11:47
One more thing I forgot to say...
...I try to make trick with WinSwup(about wich I wrote long time a go on these forum and on some other forums so!) but WinSwup can't do anything...:confused:
And I did not realase untill now that on the back sticker of these phone is writen BENQ A70 not Siemens A70!?
SST-GSM 12-05-2005 13:49
It is not important if it is written benq or siemens at the bad label.
Just upload one of the 2 eeprom files from the support site (each one for different hardware). If you want to flash phone with cut test-point with winswup connect the phone to contrast tool wait when it showsw "servise mode and connect it with winswup
hallo 12-05-2005 13:54
If You @SST just...
...read my posts above You will be see that I allredy try to do al of these advices ....without results. I can't tell taht 100% problems coused by SST...ther is posibility that these phone was factory bad in some way....
So, no hard filings? I'm just try to clear things...Cheers
hallo 12-13-2005 20:50
Sorry...
1 Attachment(s)
..I forgot to say that my A&) is working again and it was bug in 6.83 wich kill hem and make all of these thing like I alredy describe above.
So for anybody who may have the problem like I did solution is to write these eeprom to phone and phone is a live again(big thank's go's to DeDaMraz!!!)......
Sioma 12-24-2005 05:42
Hello
I need help,i do unlock A70 v32 with 6.84ver of sst,phone display wrong software
i write eeprom 1,and eeprom type 2,phone didnt turn on,than i write fullflash 8mb and bouth eeproms,phone didnt turn on
Then i read in the forum about 4mb AMD flash,i write full from support and bouth eeproms ,and phone not powered
then i write eeprom from "hallo" A70v14 eeprom repair,now phone turn on with nothing on display for 2 seconds,and when i turn on with contrast tool phone display "service mode" but winswup woount ping
Can sombody help to repair new phone???????????
hallo 12-26-2005 10:11
@Sioma....
...try to do again full flash with 4mb flash file, than write eeprom from my post and make Unlock...post res.
Cheers
Sioma 12-26-2005 15:21
I did like you say ,but phone only starts for some seconds and turn off
Thanks for help
hallo 12-27-2005 09:30
@Sioma....
1 Attachment(s)
...are You shoore that it's A70 with 4Mb Flash IC? Wich colour is phone....silver or blue? Didi You try to write 8Mb full flash? After full flash 8Mb pl's write these eeprom for 8Mb and post res.
Cheers
Sioma 12-29-2005 02:13
With your eeprom and 8mb flash phone is dead
Flash Chip : 0001227E (AMD)
Any ideas?
Page generated in 0.29264 seconds with 5 queries
