SEIMENS SX1 repairing? i have siemens sx1 flash with SST BOX ONE but after flashing the phone only beep. can't power on @ SST BOX TEAM how to solve this problem ? any body could explain this ? Br maxieboy;) |
SX1 phone is different from the other EGOLD phones. You can use SST for flashing only EGOLD (phone part). With SST to reapair a dead SX1 phone you should use fullflashing or better eeeprom flashing option. For total software repair of SX1 you should use winswup. This problem and the solution are well explained in this forum. Please use search button! |
@ SST-GSM sir Can you share me for that files for flashing ? wrking flash files thanks in advance |
i search too for SX1 Solution but there are big mass on the forum can you redirect as pls.Or short explanation for winswup. with tp or without tp how pls |
a short explanation of the repairing procedure is here: http://forum.gsmhosting.com/vbb/show...10&postcount=3 winswup can detect egold part of SX1 phones with removed resistor only if the phone is on. |
thks bro i will check |
ok but does i need tp and how to recognize old and new model thks in advice |
wich cable to use for winswup flashing |
