Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SST-Dongle
Old 08-18-2005, 17:16   #1 (permalink)
Member: 153263
SST gives me messege: Please update SST
when i start the program the window opend and there is a small window message says:Please update SST and that's it,it works few days before, but now only this message. my version was 6.50, i download 6.61 and install it but THE SAME
what to do to work with sst
thanks in advance
Old 08-18-2005, 17:48   #2 (permalink)
OvidelGSM's Avatar
Member: 103544
Sonork: 100.75677
Thanks Meter: 155
you have purchased this sst?
Old 08-18-2005, 17:51   #3 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 117
Maybe a small bug I am sure SST-GSM will check it out and fix it.For now if you dont need it do not use this new version,reinstal old version and write to support section at SST-GSM.
regards
Old 08-18-2005, 19:23   #4 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
thanks in advance
Can you please tell us your system date ?
It is needed that your system date is set correctly before installing SST
Old 08-19-2005, 08:13   #5 (permalink)
Member: 153263
I set my system date correctly but now the message says : PC clock tampered
what to do??
Old 08-19-2005, 08:43   #6 (permalink)
Member: 153263
regards
yes but it works fine few days ago, i don't need this new version, i install it because the old stop to work and says please update SST,
Old 08-19-2005, 11:45   #7 (permalink)
Member: 153263
now v6.50 works on win'98, i remove all SST programs,drivers, even in registers with regcleaner,and after 3 hours deleting,instaling..... it now works on '98, but on XP it seems to be impossible, please SST-GSM tell me how to completely remove instalation of SST where it puts f... files,i think if i remove SST completely and after that install it with the correct system date it will work.waiting your replay,hope to help me
regards
Old 08-19-2005, 11:46   #8 (permalink)
OvidelGSM's Avatar
Member: 103544
Sonork: 100.75677
Thanks Meter: 155
loool ... i think he have a cracked version
Old 08-19-2005, 12:59   #9 (permalink)
Member: 153263
IT IS NOT CRACKED VERSION!!!!!
normal sst dongle, but something is wrong here
Old 08-19-2005, 13:00   #10 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
regards
Please set correct system date on your system and at the next update everithing will be ok. When you system date is not set back or foward SST will not run .
Old 08-27-2005, 13:41   #11 (permalink)
Member: 153263
I set it correct but now what, i must wait may be months for next update?Why it is made that way, what importance have the date? now it works somehow on '98, but how long....
Old 08-27-2005, 13:49   #12 (permalink)
MACKIE's Avatar
Member: 19987
Thanks Meter: 27
Your dongle is ok...problem is that you used cracked version before you purchase your dongle and now cracked version confusing new one....thats why everything work OK on win98...you must format your hard drive and install new clean dongle version...and then everything will be OK...
Regards
Mackie
Old 08-27-2005, 15:37   #13 (permalink)
Olsenrye's Avatar
Member: 42264
Thanks Meter: 4
Format C: will help you and after you have do the make a bakup whid PowerQuest Drive Image then you always can go bak if you have a problem
Old 08-28-2005, 00:15   #14 (permalink)
danilo_nop's Avatar
Member: 31049
Thanks Meter: 4
I get same error, this ver. was working until now?!
btw I try on xp & 98se on same comp., i didnt change time....
Old 08-28-2005, 04:32   #15 (permalink)
MELDON BA's Avatar
Member: 65015
Thanks Meter: 7
got the same problem today. been using it for 3 months already.
please give me file c60 for sst chenmai E-Gold Based Phones 14 11-09-2008 16:06
Please Update SST problem sewger SST-Dongle 15 01-31-2006 09:34
please update sst bentys2000 S-Gold Based Phones 2 01-23-2005 22:01
Give me information, please! Alligator Motorola Old Legacy (EMMI) 0 10-22-2001 13:09
Page generated in 0.31460 seconds with 10 queries
