09-07-2008, 11:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: karachi pakistan Age: 35
Member: 476667 Status: Offline Thanks Meter: 56 | 1110,1112,1600,2310 contact service 100% tested solution then flash with latest flash files an do ui setting. only for hwk users post result after test wbr khan_mobiles |
The Following User Says Thank You to khan_mobiles For This Useful Post: |
09-07-2008, 11:12 | #2 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | khan mobiles. this is not 100% solution. first erase all. skip erase area. write latest flash file. do unlock. see results. write pm. do full ui,factory defaults. |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
1110,1112,1600,2310,2610,2626,6030 etc not charging brand new solution | .::ricky rayya::. | Nokia Hardware & Hardware Repair | 121 | 07-18-2013 18:12 |
nokia 1110 1112 1600 2310 6030 2610 charging ic jumper solution 100% test | m zubair | Nokia Hardware & Hardware Repair | 17 | 02-23-2011 10:03 |
Insert sim solution 1110,1112,1600,2310,2610,2310,Final | Dooha_Bd | Nokia Hardware & Hardware Repair | 9 | 03-15-2010 04:30 |
1110-1112-1600-2310 lcd gone 4 sec 100% solve | mobiletuch | Nokia Hardware & Hardware Repair | 7 | 02-05-2010 08:49 |
