05-15-2009, 04:56 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 539038 Status: Offline Thanks Meter: 11 | 1110i flash error 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032 Algorithm: u_st_i.fia, Ver: 4.76.0 Faid Error: 12 Error Data1: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00000010: 00 00 01 00 00 00 00 00 00 AD 7E B6 1A 1B BE 0B 00000020: E2 7D 58 6B E4 DB EE 65 14 CD 00 00 00 00 00 00 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Error Data2: 00000000: 00 B3 72 11 00 00 00 00 00 00 00 00 00 00 00 00 00000010: 00 00 00 00 00 00 AD 7E B6 1A 1B BE 0B E2 7D 58 00000020: 6B E4 DB EE 65 14 CD D3 72 00 00 00 00 00 00 00 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Before taking screenshot, expand this window ! Process Failed, Repowering Mobile |
05-15-2009, 11:22 | #2 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Check for cable problem, clean pad and better to use Rubber Band to hold cable. If you think that cables are ok, just go for hardware. Try to apply some heat on CPU with good quality flux. Br, Shadab Ahmad | |
05-15-2009, 13:07 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | 1110i booting error Uptate your HWK version to 2.0.8.4 post result |
The Following User Says Thank You to srinibas For This Useful Post: |
05-15-2009, 16:57 | #5 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | its cable problem or hadware cpu or flash ic... but i not solved with cable then first uninstall and install HWK software some times it also helps.... |
The Following User Says Thank You to nomi_42us For This Useful Post: |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
1110i unlocking error | microtel | Universalbox | 22 | 01-11-2007 17:13 |
1110i unlocking error | microtel | Universalbox | 1 | 11-16-2006 17:24 |
