Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 02-14-2010, 18:10   #1 (permalink)
sebY7676's Avatar
Member: 637351
1112 help
Prod.Sn : KIO745705
HW Vers : 0526
UEM : 1314
UPP : 8705 [2201]
RFIC Ver: 0500
DSP Vers: P05w06.v34
LCD Type: WINTK:SYRS00
IMEI : 352298-01-355469-0
SL Conf : FFF-FF-FFFFFFFFFFF
SL Prof : 000000000001000-0
SL Var : 00003522980135546900
SL Aux : 00020000
HW Sig : 57757D13E4F934D2
Box Id : FFFFFFFFFFFFFFFF
SL Data Corrupted
MastCode: 16 31 26 73 72
Provider: Not Found
#pw+ 928 512 043 667 020 +1#
#pw+ 086 453 104 476 661 +2#
#pw+ 817 501 334 547 012 +3#
#pw+ 493 307 712 175 317 +4#
#pw+ 427 847 646 510 751 +5#
#pw+ 316 316 130 475 522 +6#
#pw+ 946 322 161 455 432 +7#
Old 02-15-2010, 03:39   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 100.1613804
Just unlock your phone
if not ok, write rpl
Old 02-15-2010, 06:44   #3 (permalink)
sebY7676's Avatar
Member: 637351
but i cant unlock
IMEI: 352298-01-355469-0, ASIC: 2
FILE: rh93_06.000
1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.0.9.0]
2nd Boot: u_2nd.fia, Ver: 4.20.0
Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE
FLASH DEVICE NOT SUPPORTED
Check Product, Use newer Flash Loader Pack
Algorithm: u_amd.fia, Ver: 4.20.0
2nd Boot Error:
Error Data1:
00000000: 9B 01 02 01 00 EC 22 68 00 00 01 21 02 00 00 00 ......"h...!....
00000010: 01 00 00 00 00 AD 7E B6 1A 1B BE 0B E2 7D 58 6B ......~......}Xk
00000020: E4 DB EE 65 14 39 00 00 00 00 00 00 00 00 00 00 ...e.9..........
00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Error Data2:
00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000010: 00 00 AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE ...~......}Xk...
00000020: 65 14 39 D3 72 00 00 00 00 00 00 00 00 00 00 00 e.9.r...........
Before taking screenshot, expand this window !
Old 02-16-2010, 08:32   #4 (permalink)
Ramzan khan's Avatar
Member: 405696
hello write full pm and then unlock.check ur cable.and clean the software points on cell phone.
flash device not supported its mean uem problem.rehot ur ram and flash ic
Old 02-16-2010, 08:34   #5 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1590693
flash in latest version it will be direct unlocked if you are using latest suite
Old 02-16-2010, 08:38   #6 (permalink)
Member: 1236127
Sonork: 00923453696650
flash with hwk with latest verson of files
Old 02-17-2010, 20:44   #7 (permalink)
sebY7676's Avatar
Member: 637351
I TRYED, but same problem, i write rpl, but nothing.....
Old 02-17-2010, 21:53   #8 (permalink)
bahaqurini's Avatar
Member: 431775
no don't flash it on last version because maybe its not support to unlock on hwk
try to flash on on other version on not lasted one
u can go to hwk support and download file the listed supported dct4+ for unlock
there pdf file open it and see the version that support for unlock on hwk
there not with me now but if tomorrow i was on my work i will say that version u most use
Old 02-18-2010, 04:58   #9 (permalink)
Member: 405696
hardware problem
its hardware problem .rehot flash ic.or change flash ic .its working
after change flash ic u need to flash again
Old 02-18-2010, 12:46   #10 (permalink)
bahaqurini's Avatar
Member: 431775
to can unlock it on hwk u most flash in on ver 3.11 or 3.00
becuse v3.30 not support to unlock
Old 02-19-2010, 20:15   #11 (permalink)
sebY7676's Avatar
Member: 637351
solved with another tool
Nokia 1112 HELP please! meowdd Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 01-19-2010 15:03
NOKIA 1112 help ???? electro12 Nokia Hardware & Hardware-Repair Area 4 08-09-2009 11:31
Making 1112 help gsm-fault Nokia Hardware & Hardware-Repair Area 5 01-10-2008 02:55
vBulletin Optimisation provided by vB Optimise (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 0.42942 seconds with 8 queries
