06-16-2008, 14:10 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | 1200 LCD test failed... MCU Sw: V 4.11 10-11-07 RH-99 (c) NMP PPM Sw: V 4.11 10-11-07 RH-99 (c) NMP MG Prd.Cd: 0546862 Bpr.Cd: 0544418 Pro.Sn: DFT604819 HW : 1500 UEM : 1328 UPP : 8850 RFIC : 0700 DSP : P06w45.v41 LCD : UNKWN: IDs: 7f:ff:7f IMEI : 358088-01-********* SLconf: 000-00-00000000000 SLprof: 000000000001000-0 SLvar : 00003580880115787300 SLaux : 000B0000 HwSig : 633E0F8550CE6DA2 BoxId : FFFFFFFFFFFFFFFF MastCode: 36 52 16 72 42 |
06-16-2008, 14:14 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
Have u tried to flash phone to make sure it is not problem with software! Test fully first, then if that not resolve then surely common sense would say check lcd etc etc! COMMON SENSE! | |
06-16-2008, 19:31 | #4 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | the lcd and flex cable is working on another mobile , i have tested it .. it is not a LCD or cable problem and i have also flashed the set fully.. same problem remains .. any help... |
06-17-2008, 19:40 | #8 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Bro! It seems that your phone is liquid damage. Check out LCD connector on board. Clean it, try to apply solder on all pins. Be carefull when doing it as you may easily short pins if there is more solder on soldering iron's tip. If no success, change LCD connector. If yet not solved, you may need to apply jumpers to LCD Connector. In many cases, absence of VIO and VFLASH voltage will make HWK Suite to see LCD as Uknown. If these voltages are absent, jumper these voltages from other area of board. ***MOST IMPORTANT*** Does your mobile turn on? Do you see light on screen? Do you hear Keypad Tone? If all the answers are NO, then just put your board in Thinner for 15 Minutes, get it out of thinner, apply brush softly, and apply adequate heat. Your problem will be 100% solved. Good Luck Bro! Br, Shadab Ahmad |
The Following User Says Thank You to [Shadab_M] For This Useful Post: |
06-18-2008, 11:40 | #11 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Suppose, I have a N1200. It has everything as shipped by Nokia. Nothing changed. Now I flashed it with earlier version. Will it cause display problem? In my opinion, Two LCD from Different Models may look same, but may cause incompatibility issues, but LCD of a phone may not cause incompatibility issue for that phone after a software change. Br, Shadab Ahmad | |
is 1110i lcd=1200 lcd??????? | sachin_udai | Nokia Hardware & Hardware Repair | 29 | 06-16-2010 01:43 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
7650 lcd test box and 6100 and 7210/6610 test box new boxed!! | sergioems | Sell ur Old and Used Stuff | 1 | 10-17-2003 18:21 |
