05-30-2009, 18:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Lisboa.PT Age: 44
Member: 691819 Status: Offline Sonork: 1601120 Thanks Meter: 65 | 1208 SL Data Corrupted I've download the new fw (RH-105_dp_v_37_00_MCUSW5_91.exe) from suport. Don't give any error writing it on the phone, but when i make INFO gives this information. MCU SW : V 5.91 27-03-09 RH-105 (c) NMP PPM SW : V 5.91 27-03-09 RH-105 (c) NMP AG Prd.Code: 0562172 Bpr.Code: 0515534 Prod.Sn : DOK607545 HW Vers : 1602 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: SDI:NAXv89 S6B33BD IMEI : 358100-01-585498-3 SL Conf : 000-00-00000000000 SL Prof : 000000000001000-0 SL Var : 00003581000158549800 SL Aux : 000B0000 HW Sig : 892A65C16FE30989 Box Id : FFFFFFFFFFFFFFFF SL Data Corrupted Provider: Not Found If i put the 5.80 it works very good. This was just an info to ODIA and MUNNA. Tkz |
05-31-2009, 10:45 | #4 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Document is called Nokia DCT4+ Patch Unlock List and is installed to your system as part of the release. If you look in this document you will see that RH-105 is supported up to version 5.80 and that the unlock stays Permanent in the phone, so if you upgrade to a higher version of cause SL data will show as corrupted. Odia. | |
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post: |
Sl data corrupted 2760 | kishalayabiswas | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 06-10-2009 18:48 |
2630 SL Data Corrupted | jayanandana | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-23-2009 13:32 |
SL DATA CORRUPT in 6680 | denard | Nokia Base Band 5 ( BB-5 ) | 6 | 11-23-2007 11:53 |
