07-27-2009, 08:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | 1650 sl data corrupted MCU SW : V 5.30 31-03-08 RM-305 (c) NMP PPM SW : V 5.30 31-03-08 RM-305 (c) NMP MG Prd.Code: 0547172 Bpr.Code: 0515495 Prod.Sn : IBK241170 HW Vers : 2501 UEM : 1328 UPP : 8850 [2292] RFIC Ver: DSP Vers: LCD Type: SDI:GUINv86 S6B33D1 IMEI : 354869-02-178534-0 SL Conf : 000-00-00000000000 SL Prof : 000000000000000-0 SL Var : 140C00000000014003E7 SL Aux : 00000000 Box Id : 0000000001410FE0 SL Data Corrupted while init simlocks IMEI: 354869-02-178534-0, ASIC: 0 FILE: rm305_05.300 1st Boot: Ok, DCT4, UPP: 2292 [Rm-305] [2.0.8.5] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x01FFFFFF,0001327E,Amd 29NS128P Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 847642C992D0A32A19C0DAACE6 Decoded MSID: 3E4EBAE9-0010683D-A8000000 Encoded FAID: DDF65081-F08DBF11-353227CE Area1: 0x01160000-0x0117FFFF Erased, Time: 00:00 SimLocks Initialized (PM Ok), Time: 00:28 it says unknows asic id continue any way yes or no. what to do need proper guidance as i faced this problem thrice in two days. |
07-27-2009, 10:42 | #8 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
1. Write Full PM and do Init Simlock 2. A little Reheat UEM and then try again. 3. If said two solutions fail, you must use RPL to solve. Br, Shadab Ahmad | |
07-29-2009, 07:40 | #14 (permalink) | |
Cheater -Don't Deal with him- Join Date: Apr 2006 Age: 36
Member: 265129 Status: Offline Thanks Meter: 281 | Quote:
Check and Post Result. rgd. .::F@iZa/\/::. | |
The Following User Says Thank You to faizanbhatti94 For This Useful Post: |
07-29-2009, 08:27 | #15 (permalink) | |
Junior Member Join Date: Jan 2009
Member: 948616 Status: Offline Thanks Meter: 0 | Quote:
test by me..... | |
1650 sl data corrupted | pallumobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 07-23-2009 19:49 |
Sl data corrupted 2760 | kishalayabiswas | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 06-10-2009 18:48 |
SL DATA CORRUPT in 6680 | denard | Nokia Base Band 5 ( BB-5 ) | 6 | 11-23-2007 11:53 |
