1661 Contents Package Extracting Failed during flash-help i have a dead 1661-flashed-error as below 1st Boot: Ok, DCT4, UPP: 2293 [Rh-122] [2.2.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x017FFFFF,00EC2254,Sam K8S6415ET Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 842E7B6791D839A4202DAFD609 Decoded MSID: 3E4EBAE9-006D74E8-AA000000 Encoded FAID: B3DE3FFA-F69C2AEF-0DB91C5D IMAGE: rh122_005.010 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0179FFFF Erased, Time: 00:50 Area3: 0x017A0000-0x017EFFFF Erased, Time: 00:02 Area4: 0x01F00000-0x01FDFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:16 IMAGE: rh1220_nai05.01aa Area1: 0x01750000-0x0178FFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile check details as below 1st Boot: Ok, DCT4, UPP: 2293 [Rh-122] [2.2.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x017FFFFF,00EC2254,Sam K8S6415ET Algorithm: u3_amd.fia, Ver: 4.79.0 Rebooting Mobile helpppppppppppppppp meeeeeeeeee |
rehot ic and try it................... |
1: write pm and unlock to jafe divaice 2: chang lcd |
just check bsi line of the handset or mostly corbons or dust in easy cable connector. |
1.use jaf box write pm and fectry set 2.unlock chek and unlock pick the mcu file and fectry set. 3chang Lcd. good Luck |
Fool he saying here contact service problem:d Check log then write here. Try to rehot the pcb gently then flash again. And post here result. Br. Vijendra Saini. |
You probably wrote a lower version of software into the phone so it cannot power on after writing mcu and image files because the phone must power on before it can write the ppm file after extracting the necessary files to write. Solution to your dead phone: 1. Erase phone flash 2. Write any version you have 3. Write pm file to restore lost network signal as a result of the erasing of phone flash 4 Do unlock of phone 5. Full factory setting OR Look for the highest version of this phone on net and over-write the low version that killed your phone. |
Contents Package Extracting Failed THIS ERROR MEANS SET CAN'T GO TO LOCAL /TEST MOOD TRY WITH EASY CABLE MAY HELP MOSTLY THIS IS HARDWARE BUT YOU CAN TRY WITH JAF IN THIS CONDITION JAF SHOWS AFTER FLASH PROCESS FILED BOTH ERROR S ARE SAME :) |
