Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 07-25-2012, 12:31   #1 (permalink)
Member: 946381
1661 Contents Package Extracting Failed during flash-help
i have a dead 1661-flashed-error as below
1st Boot: Ok, DCT4, UPP: 2293 [Rh-122] [2.2.0.0]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x017FFFFF,00EC2254,Sam K8S6415ET
Algorithm: u3_amd.fia, Ver: 4.79.0
Algorithm Ok, MSID: 842E7B6791D839A4202DAFD609
Decoded MSID: 3E4EBAE9-006D74E8-AA000000
Encoded FAID: B3DE3FFA-F69C2AEF-0DB91C5D
IMAGE: rh122_005.010
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x0179FFFF Erased, Time: 00:50
Area3: 0x017A0000-0x017EFFFF Erased, Time: 00:02
Area4: 0x01F00000-0x01FDFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:16
IMAGE: rh1220_nai05.01aa
Area1: 0x01750000-0x0178FFFF Erased, Time: 00:02
CNT Flashing Completed, Time: 00:01
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
check details as below
Rebooting Mobile
helpppppppppppppppp meeeeeeeeee
Old 07-25-2012, 17:56   #2 (permalink)
Member: 540512
rehot ic and try it...................
Old 07-25-2012, 18:15   #3 (permalink)
Member: 1782722
Sonork: 100.1624921
Rebooting Mobile
Content serves
1: write pm and unlock to jafe divaice
2: chang lcd
Old 07-25-2012, 18:31   #4 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Rebooting Mobile
just check bsi line of the handset or mostly corbons or dust in easy cable connector.
Old 07-25-2012, 18:36   #5 (permalink)
Member: 1782722
Sonork: 100.1624921
1661 contact servce
1.use jaf box write pm and fectry set
2.unlock chek and unlock pick the mcu file and fectry set.
3chang Lcd.
good Luck
Old 07-25-2012, 23:02   #6 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Fool he saying here contact service problem:d
Check log then write here.
Try to rehot the pcb gently then flash again.
And post here result.
Br.
Vijendra Saini.
Old 07-25-2012, 23:11   #7 (permalink)
Member: 237256
You probably wrote a lower version of software into the phone so it cannot power on after writing mcu and image files because the phone must power on before it can write the ppm file after extracting the necessary files to write.
Solution to your dead phone:
1. Erase phone flash
2. Write any version you have
3. Write pm file to restore lost network signal as a result of the erasing of phone flash
4 Do unlock of phone
5. Full factory setting
OR
Look for the highest version of this phone on net and over-write the low version that killed your phone.
Old 07-28-2012, 09:13   #8 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Contents Package Extracting Failed THIS ERROR MEANS SET CAN'T GO TO LOCAL /TEST MOOD TRY WITH EASY CABLE MAY HELP MOSTLY THIS IS HARDWARE BUT YOU CAN TRY WITH JAF IN THIS CONDITION JAF SHOWS AFTER FLASH PROCESS FILED BOTH ERROR S ARE SAME
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.60132 seconds with 11 queries
