1680c-2 ver. 5.61 unlocked 1680c-2 done unlocked but 2630 ver 5.61 still not supported... Quote:
mismatch mcu version patch unlock to version of fone 1. install exe flash file same version of fone 2. open ufs+hwk icon check then info 3. click unlock it is auto detect for patch unlock |
It is Supported Mate, flash MCU & Unlock again. |
2630 ver 5.61 if still not supported then upgrade/downgrade and try again |
Hwk can not identify 2630 5.61. It shows flash device not supported use newer update pack. |
I have one cable I connect it to hwk it says flash device not supported while on jaf it identifies ok. I just done it using jaf. While We need updates for hwk because hwk can not identify latest flash chips of 2630. Quote:
Yes! Phone may have New Flash Chip & that is not supported by HWK, wish Update will not take another 6 months. |
your best br... |
1680c-2 v5.63 unlock? |
hi Quote:
how to unlock this model bro 1680c-2 can u help me step by step please best regards aziz |
your welcome brother post version and model post info log using hwk |
good work friend thanks |
can u add me brother [email protected] |
watch this log 1680c using jaf Getting MCU ID MCU ID: 0x3162 FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.61 18-04-08 RM-394 (c) Nokia HW version: venuno PCI version: UEM version: 1328 UPP version: 12642 RFIC version: 0500 DSP version: P06w45.v48 LCD version: SUEZ PPM version: V 05.61 18-04-08 RM-394 (c) Nokia T Content Pack version: Content: opv_globe V 05.61 18-04-08 RM-394 (c) Nokia Production serial number: IFO310619 Product code: 0567449 Module code: 0203777 Basic production code: 0556746 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: venuno IMEI spare to net: 3A 65 87 02 82 73 89 04 IMEI SV to net: 33 65 87 02 82 73 89 34 F0 Master Code: 74venuno503 Phone type: RM-394, Software version: 05.61, Language Pack: T User code: 12345 Block 1: Lock 1: CLOSED -> Lock Data: 51502F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-394.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: \Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! Powering the phone... Unlocking... IMEI: venuno ASIC: b SW version: 05.61 Stoping... Powering the phone... Unlocking... IMEI: venuno ASIC: b SW version: 05.61 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rm-394 1680c\rm394__05.61.mcusw Decrypting flash...Done Checking ROM call...Done Checking security function...Done Encrypting....Done Patch status: 00 MCU ID: 0x3162 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E310100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: a2 Loader is ready... P-key nokia module version 01.02 MSID: 84F13F239E636A0002DAF6E8BF MSID decoded: 2C40BAE9008717F6AA000000 FAID: 41BE03140927C92B3476EBFA Erasing area: 01000000 - 0101FFFF... Erasing area: 01080000 - 0109FFFF... Perm. Data Restore OK Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 98 __________________ |
