12-07-2008, 12:33
#1 (permalink)
Member: 470292
Thanks Meter: 147 | 5200 Flash Problem I have flashed it to Latest version but still Phone shows only nokia and then Hang and white screen. It also takes so long time in Ui Settings.. Check below log.... Quote:
1ST BOOT : C0,07 [Rm-174] [2.0.8.0]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 1BB00101DDEC5F561F4F63446F73B1DD4BFC9957
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0
CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0
CMT KSIG0 : D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm174__07.00.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:41
CMT FLASH WRITE OK, Time: 05:52
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
128K Image Saved as: rm174__07.00.image_i_black_128
IMAGE : rm174__07.00.image_i_black_128
CMT NOR Erase Area: 0x01500000-01FDFFFF
CNT FLASH ERASE OK, Time: 00:16
CNT FLASH WRITE OK, Time: 01:50
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm174__07.00.ppm_i
CMT NOR Erase Area: 0x01080000-014FFFFF
PPM FLASH ERASE OK, Time: 00:09
PPM FLASH WRITE OK, Time: 01:18
Flashing Completed, Rebooting Mobile
| I did ui setting as below.. Quote:
UI Defaults Ok, Time: 00:32
Set UI Factory Defaults Ok, Time: 00:33
Set Full Factory Defaults Ok, Time: 00:33
Set Software Upgrade Defaults Ok, Time: 00:33
Set Security Ok, Time: 00:16
| Phone Gives info sometimes only one time I succeded to get it.. Quote:
MCU SW : V 07.00 19-08-08 RM-174 (c) Nokia.
PPM SW : V 07.00 19-08-08 RM-174 (c) Nokia. I
Prd.Code: 0541038
Bpr.Code: 0530542
Prod.Sn : DAH190999
HW Vers : 2002
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w10
IMEI : 355537-01-131857-5
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Stat : 0000000000000000
SL Count: 00 00
Provider: Nokia Test;Finland
| Any good idea .... |
