Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 12-07-2010, 10:05   #1 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
2610 phone dead after flash?
2610 phone is dead after flash phone imei is strange starts from 011xxxxxxxxx flashed it with latest firmware 7.11 and also it flashed ok
MCU SW : V 07.11 05-11-08 RH-86 (c) Nokia.
PPM SW : V 07.11 05-11-08 RH-86_87 (c) Nokia. IA
Product : Nokia 2610
Prd.Code: 0533407
Bpr.Code: 0530409
Prod.Sn : DMJ191887
HW Vers : 1000
UEM : 1328
UPP : 12352 [3040]
RFIC Ver: 0500
DSP Vers: P05w45.v49
LCD Type: ELBE
IMEI : 011287-xx-xxxxxx-x
SL Conf : 001-01-00000000000
SL Prof : 800000000001000-B
SL Var : 00550112870020608800
SL Aux : 000B5555
HW Sig : 2CEAB38FAD8D3E0F
Box Id : 894F8BD2FFFFFFFF
BLK1= L1: UNKN L2: UNKN L3: UNKN L4: AUTO L5: UNKN
BLK2= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN
BLK3= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN
BLK4= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN
BLK5= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN
BLK6= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN
BLK7= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: AUTO
Provider: GSM Test Equipment
also n selftest everything is ok except lcd test it show not supported... phone is not powering on whats the big idea now i m confused.....
(phone was having minor hang fault b4 flashing)
need urgent solution.......................:confused :
Old 12-07-2010, 13:18   #2 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
your phone is not dead but you have problem with LCD.
with dead phone you can't make info from it.
so better to give more details about the initial state of your phone before flashing
imei 011287-xx-xxxxxx-x is not a problem it is from america and canada.
goo luck
Old 12-07-2010, 13:52   #3 (permalink)
Member: 1346463
Thanks Meter: 45
erase 7.11 & flash with 6.65
this phone is not rh-86
erase ur phone & flash with rh-87 6.65 100% tested ......
Old 12-07-2010, 14:25   #4 (permalink)
GSM_STREET's Avatar
Member: 1149815
Sonork: N/A for now
Thanks Meter: 218
Simlock Blocks Unknown the phone is dead
The Following User Says Thank You to GSM_STREET For This Useful Post:
Old 12-07-2010, 15:39   #5 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 568
Maybe
Prd.Code: 0533407
Bpr.Code: 0530409
Prod.Sn : DMJ191887
HW Vers : 1000
UEM : 1328
UPP : 12352 [3040]
RFIC Ver: 0500
LCD Type: ELBE
SL Aux : 000B5555
Hi
Try Make Ask to Rpl, wirte rpl again.
Then Full factory
Or Water DAamage ;(
Polish
Old 12-07-2010, 15:47   #6 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Remove facia and you see Contact Service there while turning on.
And about SIMLOCK Info, HWK Showns UNKNOWN for both 2626 and 2610.
Check back label to determine its type eg. RH-86 or RH-87. Flash with appropirate files, you may also try to erase phone and then full flash.
You may also compare IMEI in Info with Back label.
Br,
Shadab Ahmad
Old 12-08-2010, 08:57   #7 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
Br,
Shadab Ahmad
everything is perfect considering its back label and logs info..............
i already done every bit of things that u ppl told me ................
something is fishy
Old 12-08-2010, 09:18   #8 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
yes there was an other back label sticker when i removed it. it is 2610b so it means that this phone is converted to 2610 so can i go for it with 2610 firmware or is it nessry to flash it with 2610b if yes so which version would work for me............??????????
Old 12-08-2010, 09:41   #9 (permalink)
Member: 60668
Thanks Meter: 69
possibly its 2610b v.7.04a, you cannot flash this phone with other firmware coz phone seems dead but you can check info, flash it with correct firmware,
Old 12-08-2010, 10:14   #10 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
ok thanks bro phone is on but has no network also phone restarts once when u power on and after some times when phone is on it powers off also it is a bit bump or can say slow..................... so now need more help...........
Old 12-08-2010, 12:51   #11 (permalink)
Member: 60668
Thanks Meter: 69
just write 2610 pm and do full factory reset.
Old 12-08-2010, 13:04   #12 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
already done tht no use other solution.................
Old 12-08-2010, 13:34   #13 (permalink)
Member: 60668
Thanks Meter: 69
does ringtones ring slowly? if so, change clock crystal.
Old 12-08-2010, 14:21   #14 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
he can't retreive network signal without hardware modification.
@decentevil
try to amke searche with
convert 2610b to 2610
ther is two filter to change
good luck
Old 12-08-2010, 14:25   #15 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 297
sorry double post
wbr adel
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.27899 seconds with 10 queries
