Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 04-08-2012, 09:57   #1 (permalink)
Member: 1714279
2700c sl data read failed
before flash :
MCU SW : V 09.80 02-12-09 RM-561 (c) Nokia
PPM SW : V 09.80 02-12-09 RM-561 (c) Nokia EL
Prd.Code: 0579811
Bpr.Code: 0577212
Prod.Sn : IAY895836
HW Vers : 2000
EM VILMA: A-
EM BETTY: 22
RFIC Ver: 06540601
DSP Vers: ICPR72_09w26
LCD Type: SEIKO
IMEI : 351547-04-292951-8
Prd.Code: A
Bpr.Code: 0577212
Prod.Sn : IAY895836
HW Vers : 2000
EM VILMA: 16
EM BETTY: A,
RFIC Ver: 06540601
LCD Type: SEIKO
SL Conf : 000-00-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
SL Data Read Failed
SL Data Read Failed
Provider: Not Found
flashing log :
Detected: V 09.80 02-12-09 RM-561 (c) Nokia
1ST BOOT : C0,07 [Rm-561] [2.2.0.3]
CMT ASICID: 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT PUBID : 17100102BE96495065C4B09D16E60C25F45B9562
CMT MODE : 00
CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROMID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898982-00008A31, Int NU48F512
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT KSIG0 : 3EA22A1DDA660002E56108DB5072A10F8709443F
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm561__09.95.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-0137FFFF
CMT NOR Erase Area: 0x01380000-0151FFFF
CMT FLASH ERASE OK, Time: 01:50
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 02:06
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
CONVERSION: Already 128K Paged Source
IMAGE : rm561__09.95.image_mena_a_blac
CMT NOR Erase Area: 0x01DC0000-0215FFFF
CMT NOR Erase Area: 0x02160000-03FBFFFF
CNT FLASH ERASE OK, Time: 02:02
CNT FLASH WRITE OK, Time: 00:51
IMAGE : rm561__09.95.ppm_mena_a
CMT NOR Erase Area: 0x01520000-01DBFFFF
PPM FLASH ERASE OK, Time: 00:29
PPM FLASH WRITE OK, Time: 00:34
Flashing Completed, Rebooting Mobile
Set UI Defaults ...
UI Defaults Ok, Time: 00:16
Set UI Factory Defaults ...
Set UI Factory Defaults Ok, Time: 00:14
Set Full Factory Defaults ...
Set Full Factory Defaults Ok, Time: 00:14
Set Security 12345 ...
Set Security Ok, Time: 00:03
All Done, Time: 09:06
after flash :
MCU SW : V 09.95 02-04-10 RM-561 (c) Nokia
PPM SW : V 09.95 02-04-10 RM-561 (c) Nokia MH
Product : Nokia 2700 classic
Prd.Code: 0579811
Bpr.Code: 0577212
Prod.Sn : IAY895836
HW Vers : 2000
EM VILMA: 16
EM BETTY: 22
RFIC Ver: 06540601
LCD Type: SEIKO
CAM Prim: NIMMIIIIRRFF00000000_XXXXXX (DCC Mismatch)
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Count: 00 00
SL Data Read Failed
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
The Following User Says Thank You to v-link For This Useful Post:
Old 04-08-2012, 17:10   #2 (permalink)
kindo's Avatar
Member: 300886
camera hardware problem or any related h/ware to camera. try remove a camera module then reflash
b.r
kindo
Old 04-08-2012, 17:18   #3 (permalink)
Member: 540512
you need sd repair.......... hwk cant repair this problem use other online servce box like ub box
Old 04-09-2012, 08:18   #4 (permalink)
Member: 1714279
b.r
kindo
thanks for reply bro
i am not asking about camera problem
it can be solve by writing dcc file or hardware if damage
i am asking about SL Data Read Failed - check thread title
set is working correctly with & without sim but box shows SL Data Read Failed
i checked with 5130c and same [but not with every set - cable is tested]
Old 04-09-2012, 08:34   #5 (permalink)
.::RAM MOBILE::.'s Avatar
Member: 1681461
Sonork: 100.1637223
Nokia 2700 filas 100% ok
i need nokia 2700 nokia logo after White lcd
Old 04-10-2012, 18:56   #6 (permalink)
kindo's Avatar
Member: 300886
yes i know your problem is sl data read fail. but when your set had problem in local or test mode because of h/ware related, sometime it will infected on phone firmware when u reading infos. just a piece of opinion.
b.r
kindo
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 09-22-2011 15:55
Cellular Data Suite Cables avaliable !!! vingis Main Sales Section 0 11-02-1999 16:35
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 nk.cable Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-14-1999 15:33
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-26-1999 14:31
Page generated in 0.51466 seconds with 11 queries
