Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 03-09-2008, 15:34   #1 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
3110 data blk error
i have 3110 when i try to flash set by hwk its show this error
DATA_BLK_ERROR at: 0x00620400, 03
would u like to continue any way....
log....
1ST BOOT : C0,07 [Rm-217]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 0A4002059C4B6B560D14A6E51C333A2551B704D6
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.21.0
CMT FLID0 : 00EC22FE-00006921, Sam K5X5629ATM
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
CMT KSIG0 : 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
CMT VPP : Internal
CMT ALG Boot OK
IMAGE : rm217__04.20.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 01:39
ERR: CMT FLASH WRITE D_BLK C7012D0103CD000000000000F172, LN: 0x004000, Time: 04:44
Process Failed, Repowering Mobile
The Following 12 Users Say Thank You to vinay_sharma For This Useful Post:
Old 03-09-2008, 16:11   #2 (permalink)
reimon23's Avatar
Member: 268175
Thanks Meter: 198
it is a cable problem mate...
just encountered that then i changed the cable and flash it again...
works fined...
The Following User Says Thank You to reimon23 For This Useful Post:
Old 03-09-2008, 17:00   #3 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
log....
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
CMT ALG Boot OK
unchak the option of duail line mode and then flash maybe ur problem solved.
The Following 5 Users Say Thank You to NADEEM GONDAL For This Useful Post:
Old 03-10-2008, 15:49   #4 (permalink)
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
Done!
use 7pins.... cable and chk dual line option and flash again done !!
The Following 3 Users Say Thank You to vinay_sharma For This Useful Post:
Old 03-19-2008, 07:33   #5 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
no that is not a cable problem, all set like that is ok in mt-box
M A Sabah
Malappuram
The Following 4 Users Say Thank You to Abussabah For This Useful Post:
Old 04-29-2008, 15:36   #6 (permalink)
Member: 6313
N80, i test my cable in a small UFS and works
mine is an old Twister with HWK
CMT NOR Erase Area: 0x00080000-00734BD1
CMT NOR Erase Area: 0x00000000-0005FFFF
CMT NOR Erase Area: 0x001E0000-001FFFFF
CMT NOR Erase Area: 0x00880000-00FDFFFF
CMT FLASH ERASE OK, Time: 00:03
DATA_BLK_ERROR at: 0x00080000, 03
ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x000240, Time: 00:08
Old 04-29-2008, 16:41   #7 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
@maucontacto
This Can Be in Case of Bad 7 Pin Cable (TX2 pin) CMT Boot and Erase, Not Use This Pin So You have Error when Flash Wting Sarts....!
Munna.
Old 04-29-2008, 17:22   #8 (permalink)
Member: 6313
Originally Posted by GsmMunna View Post
@maucontacto
Munna.
Hi
My Twister w/HWK is different from new smaller UFS?
Where can i find scheme cable?
The Following User Says Thank You to maucontacto For This Useful Post:
Old 04-29-2008, 18:22   #9 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
Arrow
Originally Posted by maucontacto View Post
Hi
7 Pin Cables Has Nothing to Do With H/W...!
Munna.
The Following 2 Users Say Thank You to GsmMunna For This Useful Post:
Old 04-29-2008, 19:58   #10 (permalink)
Member: 6313
i use my cable in a small UFS with the same fone and it works good, when i use in mine it gives me the error
Old 04-30-2008, 05:58   #11 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Maybe your Twister is first generation (10 pin) and has not been modified to work with 8 pin cables?
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 05-03-2008, 09:43   #12 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
Old Twister
Odia.
then there is any way to convert, plz give us any solution
Old 05-03-2008, 10:42   #13 (permalink)
Member: 4042
Try to make a search in the twister section, you should be able to find out how in there.
Odia.
Old 05-04-2008, 03:56   #14 (permalink)
Member: 6313
Hi!!
I donīt find nothing talking in modifications of old Twister Ufs3 like mine, can you give us a link?
Old 04-18-2010, 18:24   #15 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i am also facing this same data blk error many time with HWK but we can sometime revive the set with another tool with same cable ...
why does this happens , what is the best way to check what causes this problem ?
The Following User Says Thank You to gsmsikar For This Useful Post:
5200 show data blk error. mayank bajaj Nokia Base Band 5 ( BB-5 ) 8 08-05-2011 14:09
Nokia 5220 data blk error bebenatower HWK 4 05-21-2011 05:35
3110c data blk error mahesh123 HWK 16 09-04-2010 18:37
3250 Data Blk Error [Shadab_M] HWK 1 06-25-2008 14:12
Bb5 Flashing Data Blk Error kankandeka Nokia Base Band 5 ( BB-5 ) 0 05-18-2008 19:34
Page generated in 0.26930 seconds with 10 queries
