Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 01-21-2010, 08:46   #1 (permalink)
Member: 839770
Thanks Meter: 24
3110c, can't start up normally, flashing ok
All brother, help urgently pls after having many times successful in flashing 3110c now i got weird thing about this phone, i have flashed the phone completely and went to be ok,then i try to power on but can't start up normally then phone dead later smoothly, good solution pls???
1ST BOOT : C0,07 [Rm-237] [2.0.9.0]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 1D9000164C826C56C3B6B84933518797EE9D6F98
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 0020881C-00006A21, St M58LR256KC
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
INFO_2ND : APE Chip Absent
INFO_ALG : APE Chip Absent
Rebooting Mobile
MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia.
PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. X
Prd.Code: 0514959
Bpr.Code: 0542523
Prod.Sn : 7G0546013
HW Vers : 2000
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w10
IMEI : 356974-01-116254-8
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm237__07.21.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-0031FFFF
CMT NOR Erase Area: 0x00320000-0105FFFF
CMT NOR Erase Area: 0x01060000-01067FFF
CMT NOR Erase Area: 0x01068000-0107FFFF
CMT FLASH ERASE OK, Time: 00:54
Written: 10 Certificate(s)
CMT FLASH WRITE OK, Time: 01:43
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
128K Image Saved as: rm237__07.21.image_x_blue_128
IMAGE : rm237__07.21.image_x_blue_128
CMT NOR Erase Area: 0x01520000-01FDFFFF
CNT FLASH ERASE OK, Time: 00:45
CNT FLASH WRITE OK, Time: 00:39
IMAGE : rm237__07.21.ppm_x
CMT NOR Erase Area: 0x01080000-0151FFFF
PPM FLASH ERASE OK, Time: 00:17
PPM FLASH WRITE OK, Time: 00:31
Flashing Completed, Rebooting Mobile
UI Defaults Ok, Time: 00:05
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults Ok, Time: 00:00
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
The Following User Says Thank You to dinoadropy For This Useful Post:
Old 01-21-2010, 08:51   #2 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
Rebooting Mobile
Prd.Code: 0514959
Bpr.Code: 0542523
Prod.Sn : 7G0546013
HW Vers : 2000
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
SL Count: 00 00
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
try to rehot the RETU
The Following User Says Thank You to genci titi 2002 For This Useful Post:
Old 01-21-2010, 10:54   #3 (permalink)
Member: 1086393
Thanks Meter: 771
100% hardware-- yes try by rehoting/reballing/replacing retu
The Following User Says Thank You to Riteshgpt60 For This Useful Post:
Old 01-25-2010, 03:24   #4 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Check On,Off button
Old 01-31-2010, 14:51   #5 (permalink)
Crazy Poster
Member: 681334
Sonork: 100.1650348
Thanks Meter: 8
Thumbs down
On,Off button 100% ok
Old 01-31-2010, 15:04   #6 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
pls resold power button
3110c after start up blink 3 times and go off intelp3 Nokia Base Band 5 ( BB-5 ) 5 10-04-2009 15:25
n5320 can't start up after flashing linglily J.A.F. By Jafsupport.com 4 03-12-2009 18:52
E730 start-up hang, cant ok UST-PRO2 reaz.com UST Pro II 0 11-21-2006 17:00
E730 start-up hang, cant ok UST-PRO2 reaz.com UST Pro II 0 11-21-2006 16:51
T610 water damaged -- can't power up but flashes ok andreic Sony Ericsson Hardware Repair 2 05-23-2004 13:06
Page generated in 0.52768 seconds with 9 queries
