03-09-2009, 16:33 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 302843 Status: Offline Thanks Meter: 111 | 3110c data blk error CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0 CMT FLID0 : 00898981-00000000, Int NU48F256 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__07.21.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:01 DATA_BLK_ERROR at: 0x00020000, 00 ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x000280, Time: 00:04 Process Failed, Repowering Mobile |
The Following User Says Thank You to mahesh123 For This Useful Post: |
09-17-2009, 08:35 | #7 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1106560 Status: Offline Sonork: dhar Thanks Meter: 0 | dear sir when i solve this problem ? (model no3110c) box UFS-2 V-2.0.9.0 CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0 CMT FLID0 : 00898981-00000000, Int NU48F256 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__07.21.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:01 DATA_BLK_ERROR at: 0x00020000, 00 ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x000280, Time: 00:04 Process Failed, Repowering Mobile error_use 5 pin cable |
09-18-2009, 22:48 | #8 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 71 | usb flashing work 100% me too have the same problem, i change cable, rehot the flash chip and i use another HWk an no result; i try with UB box with FBUS cable same error but when i flash it with USB cable now the phone is ok . i think there is an error in FBUS connection with the Int NU48F256 |
10-01-2009, 08:05 | #12 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | hey bro's HERE IS NEW n HOT SOLUTIN FOR CMT DATA BLACK ERROR before trying hardware try in software only>>>>> There r four steps to solve this problem in software>>>> 1) Try with 5pin cable 2) Try with 7pin cable 3) Try dualline mode with 7pin cable 4) Last one is just uncheck dualline mode & 1331 ur problem will b solved |
10-06-2009, 09:18 | #13 (permalink) |
Junior Member Join Date: May 2007
Member: 514471 Status: Offline Thanks Meter: 4 | this is flash files problem. chick this adress and download files http://forum.gsmhosting.com/vbb/showthread.php?t=786350 click here flash ok |
3110 data blk error | vinay_sharma | HWK | 99 | 08-12-2014 14:10 |
Nokia 3110c Data blk error | logicmobile | Nokia Base Band 5 ( BB-5 ) | 25 | 12-04-2011 07:12 |
3110c data blk error-perfect soln | zandoo | HWK | 27 | 10-28-2010 15:17 |
3110c data blk error | jaysukh | HWK | 5 | 11-30-2009 11:16 |
Bb5 Flashing Data Blk Error | kankandeka | Nokia Base Band 5 ( BB-5 ) | 0 | 05-18-2008 19:34 |
