5130 c-2 contact service help me ??? 5130 c-2 contact service here is log : MCU SW : V 06.93 20-05-09 RM-495 (c) Nokia PPM SW : V 06.93 20-05-09 RM-495 (c) Nokia MH Prd.Code: 0577793 Bpr.Code: 0567772 Prod.Sn : IIO549485 HW Vers : 2000 EM VILMA: 16 EM BETTY: 22 RFIC Ver: 06540601 DSP Vers: ICPR72_09w04 LCD Type: SEIKO IMEI : 359329-02-xxxxxx SL Serv : SIMLOCK SERVER SL Conf : 000-00-00000000000 SL Prof : 0141191F00000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found |
just RPL solved this dont try any other solution Because you lost your time. ------ lahdache |
only rpl is solution . otherwise try Universal box for repair sl data . after tht ur imei still 123456 thn also u hav 2 write rpl. |
You Need ask2rpl to solve ur problem |
this issue is solve only write rpl your problem solve 100% |
thanksssssssssssssssssssssssssssssssssssssssssssss s |
hone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35417903158495-0 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed |
howcan solve this brathers tell me i think hi is sim data repair only |
genie universal clip solve his |
there is no solution at moment with hwk. u can try other tool |
2: Get RPL and write with your device is only solution 3: For more don't make more post just use search button U will find too much about your Problum |
http://forum.gsmhosting.com/vbb/show...15#post5341515 nokia 5130 sl3 contact service 100% ok in mx key |
