Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 10-24-2009, 08:39   #1 (permalink)
gagan_o5's Avatar
Member: 602830
Arrow 5130 c-2 contact service help me ???
5130 c-2 contact service here is log :
MCU SW : V 06.93 20-05-09 RM-495 (c) Nokia
PPM SW : V 06.93 20-05-09 RM-495 (c) Nokia MH
Prd.Code: 0577793
Bpr.Code: 0567772
Prod.Sn : IIO549485
HW Vers : 2000
EM VILMA: 16
EM BETTY: 22
RFIC Ver: 06540601
DSP Vers: ICPR72_09w04
LCD Type: SEIKO
IMEI : 359329-02-xxxxxx
SL Serv : SIMLOCK SERVER
SL Conf : 000-00-00000000000
SL Prof : 0141191F00000000
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
Old 10-24-2009, 08:50   #2 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1626059
Prd.Code: 0577793
Bpr.Code: 0567772
Prod.Sn : IIO549485
HW Vers : 2000
EM VILMA: 16
EM BETTY: 22
RFIC Ver: 06540601
LCD Type: SEIKO
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
just RPL solved this
dont try any other solution Because you lost your time.
lahdache
The Following User Says Thank You to lahdache For This Useful Post:
Old 10-25-2009, 18:28   #3 (permalink)
NokiaMobileCare's Avatar
Member: 652870
only rpl is solution . otherwise try Universal box for repair sl data . after tht ur imei still 123456
thn also u hav 2 write rpl.
Old 10-26-2009, 07:42   #4 (permalink)
Master Software's Avatar
Member: 1149013
Sonork: 100.1601838
You Need ask2rpl to solve ur problem
Old 10-26-2009, 07:45   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
this issue is solve only write rpl your problem solve 100%
Old 10-28-2009, 16:28   #6 (permalink)
Member: 670719
thanksssssssssssssssssssssssssssssssssssssssssssss s
Old 01-30-2010, 09:11   #7 (permalink)
Member: 484608
hone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 35417903158495-0
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Old 01-30-2010, 09:12   #8 (permalink)
Member: 484608
howcan solve this brathers tell me i think hi is sim data repair only
Old 01-30-2010, 09:13   #9 (permalink)
Member: 484608
genie universal clip solve his
Old 01-30-2010, 09:20   #10 (permalink)
agadir5241's Avatar
Member: 771019
there is no solution at moment with hwk. u can try other tool
Old 01-30-2010, 10:22   #11 (permalink)
metals's Avatar
Member: 811779
Language Pack:
- not available.
SIMLOCK invalid!
1:Don't Forget this is HWK section . your logfile is created with another device
2: Get RPL and write with your device is only solution
3: For more don't make more post just use search button U will find too much about your Problum
Old 01-30-2010, 11:54   #12 (permalink)
Member: 1116719
see hare nokia 5130c contact service
The Following User Says Thank You to >>.123.<< For This Useful Post:
Old 01-30-2010, 12:54   #13 (permalink)
Member: 1116719
http://forum.gsmhosting.com/vbb/show...15#post5341515
nokia 5130 sl3 contact service 100% ok in mx key
Old 01-30-2010, 13:13   #14 (permalink)
Member: 36715
incase if you havent noticed he has super dongle invalid, the only solution is with credits or rpl
The Following User Says Thank You to jacob For This Useful Post:
nokia 5130 contact service help me shafi816 Nokia Base Band 5 ( BB-5 ) 11 03-25-2010 09:41
5130c-2 contact service,,help me bluetut MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-03-2010 10:07
5130 contact service help me mdmosheur MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-13-2010 13:33
5130 contact service help me thethi MT-BOX 17 12-26-2009 18:31
Page generated in 0.32300 seconds with 11 queries
