Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Saras Boxes > HWK
Old 05-26-2011, 12:17   #31 (permalink)
amanhalwara's Avatar
Member: 492884
same problem me i try many set same problem other device flash done
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 05-26-2011, 13:24   #32 (permalink)
Member: 821900
Originally Posted by tandaganon View Post
heres the logs
1ST BOOT : C0,07 [Rm-495] [2.0.8.5]
RAPx ID : 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx PBID : 237001090F997D563BC683E054F54A5DBC37B203
RAPx MODE : 00
RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT UNKID : 32 02FFFFFFFFC800
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
00000000: 02 00 00 00 00 D1 72 ......r
ERR: CMT ALG Boot CERT MISM
IMAGE : rm495__06.65.mcusw
Process Failed, Repowering Mobile
what is the possible problem with this
thanks
i haVE SAME PROBLEM CABEL IS OK I REHOT CPU NOTHING SOLVED ANY ONE HAVE 100%%% SOLUTION
Old 05-27-2011, 13:25   #33 (permalink)
Member: 472592
Bro,
No need to reboll flash or cpu, just use JAF or MXKEY usb flashing,set will be ok
i had also the same problem with ufs usb flashing, but from same cable and MXkey or JAF the problem Solved
Regards
Naushad Farsi
Old 05-27-2011, 16:16   #34 (permalink)
Member: 57108
NOT ALL BB5 PHONES SUPPORTED BY USB FLASHING !!!!!!
only listet !!!
try flash with fbus cable
stupsi99
Old 01-27-2012, 12:48   #35 (permalink)
Member: 521697
Originally Posted by bigbag69 View Post
it's 100% hardware problem.. rehot or reball flash ic...
where is the flash ic u told combo then
Old 02-19-2012, 06:00   #36 (permalink)
Member: 1248239
Sonork: 12345
rehot ic 1000000000000000000000000%ok
Old 02-19-2012, 07:07   #37 (permalink)
Member: 1534430
Sonork: jhongsky
heres the logs
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
thanks
check your cable,, an if still same rehot RAP ic carefully.....
Old 04-01-2012, 18:10   #38 (permalink)
Crazy Poster
Member: 497268
100% flash ic reball or change it. problem solved. tested by me 2 times.
N73 flash problem. ERR: CMT ALG Boot CERT MISM rocchinolatino HWK 5 06-12-2010 10:25
nokia 3110 flashing withh hwk for ERR: CMT ALG Boot CERT MISM MANISHCHAWLA HWK 9 11-02-2009 03:04
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 1.34181 seconds with 10 queries
