08-19-2009, 12:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2002 Location: La La Land Age: 43
Member: 17800 Status: Offline Thanks Meter: 8 | 5310 unlocked with HWK PPM SW : V 58.58 15-10-08 RM-303 (c) Nokia O Prd.Code: 0575286 Bpr.Code: 0544850 Prod.Sn : KPB180149 HW Vers : 2013 EM VILMA: 15 EM BETTY: 22 RFIC Ver: 06540609 DSP Vers: ICPR71_08w22 LCD Type: SEIKO IMEI : 351934-03-339638-8 SL Serv : SIMLOCK SERVER SL Conf : 234-33-00000000000 SL Prof : 8000000000000000 SL Count: 00 00 BLK1= L1: CLOS BLK2= L1: CLOS Provider: Orange;United Kingdom IMEI : 351934-03-339638-8 SLserv: SIMLOCK SERVER SLconf: 234-33-00000000000 SLstat: 8000000000000000 SL_Cnt: 00 00 Saved as Rm-303_351934033396388_819200923231_Back_308.pm, 16539 byte(s) Not found required data Process aborted 1ST BOOT : C0,07 [Rm-303] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101013000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 20000204AD535A5021E97DD45BF027379BC91837 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC220C-00008921, Sam K8F1215ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 7C5A155352F06B1ED9191D9B5EAC4AB486D40710 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent CMT NPC Certificate: 20480 byte(s) PROD: 0575286 HID0: 6322029861838749BB340000646F724200000000 PBID: 20000204AD535A5021E97DD45BF027379BC91837 PSIG: 7C5A155352F06B1ED9191D9B5EAC4AB486D40710 HID1: 3DBC258BB1445CEB3B358EB84FD0868308E97885 IMEI: 351934-03-339638-8 BTID: D68F167D24 Saved as: Rm-303_351934033396388_819200923300_NPCCmt.bin Saved as: Rm-303_351934033396388_819200923300.ask CER FLASH ERASE OK, Time: 00:00 SX4 Bypass Done, can Write PM now ... After all Done Restore it Back Using [Wr Cert] |
08-20-2009, 06:33 | #6 (permalink) |
No Life Poster Join Date: Jul 2008 Location: china guangzhou Age: 35
Member: 812359 Status: Offline Sonork: 100.1597111 Thanks Meter: 6,791 | test;use the free software bb5 unlock v2.01,connect hwk,select ufs,after,click the unlock bb5+ test ok,unlock done. but if you use the bb5 unlock V2.01 tool,don't connect jaf peky\mxkey....any pkey in you pc. |
08-20-2009, 09:19 | #12 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | Quote:
Sir free software can not be........ for this version 58.58..... check the first post well......... Thanks | |
3125 Unlocking With Hwk After Flash With Ruim | PASSIONATE_BOYS | HWK | 4 | 01-08-2010 12:04 |
2630 cant patch unlock with HWK, but with JAF+ufu Yes | boucettay | HWK | 8 | 10-29-2008 11:23 |
sharp 802 dead after unlock with hwk!?!? | et.com | Sharp | 11 | 10-28-2005 06:30 |
J300i unlock with Hwk | concept | HWK | 1 | 08-22-2005 19:49 |
J300i unlock with Hwk | concept | HWK | 0 | 08-22-2005 19:02 |
