5530 when i try to flash it with ufs and i am using ufcv2 cable no(7) 8pin 10 pin 1ST BOOT : C0,07 [Rm-504] [2.0.9.0] RAPx ID : 000000010000022600010006400C192101051105 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 1B10010D7B80005205E8337DBB7FC1D3663D0243 RAPx MODE : 00 RAPx HASH : B8C3ADECFC997FCD8081D3DEAF870B8C RAPx ROID : 4B9B75103E691FF8 CMT 1ST Boot OK Boot not Found: ASIC not Supported CMT 2ND Bt: ASIC not Supported BAD BOOT ERR: CMT 2ND Boot Rebooting Mobile plz can any 1 tell me what is the problem? |
use good modified cable for this phone better to use MT with 10 pin cable ;) |
Odia. |
I have the x-FBUS BUT I WAS PLANING On buying the UFC V2 cable if it is not good please let me know that you. Another thing i would like to know the fbus pinout for nokia 5530 because connect the N78 5pin connector xFbus and it shows me that the phone is connect but it is not reading the phone at all i use bsi switch 3.3k to 10k |
Click Here may be helpful for you did you have gnd pin seperatly and attached to battery gnd pin |
i did still same problem it looks like the original cable is the best |
Code: UFC V2 = Useless Fcuked Cable V2? |
R YOU KNOW THIS CABLE ALSO CAN BE USED AS JUNGLE CABLE please use search button i think you can find much much more next is totaly on your answer br, |
I have the cable Universal UFC and use the tip number 7 in 5530, and I can not read any communication with the box, I need to use another type of cable newer version? and what is the different between this one for the other that you guys talk about the V2 version? |
i flashed 5530 with ufc2 working great it fast and good respond thanks ufc team |
