Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 05-31-2008, 20:27   #1 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Exclamation 6110n Error Flashing !!
Old 06-01-2008, 19:27   #2 (permalink)
yawarniazi's Avatar
Member: 194128
Are you sure that the PPM file you are going to flash is similar to the MCU currently inside the phone?
If yes then try to flash the phone with all three files MCU+PPM+UDA.
OR
Then its some kind of hardware fault.
Best Regards!
yawarniazi
Old 06-01-2008, 21:29   #3 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
OR
Best Regards!
yawarniazi
writhing PPM by other tools is ok !!
Old 06-01-2008, 23:28   #4 (permalink)
dejanp's Avatar
Member: 82990
please check rx2 line in your fbus cable
Old 06-02-2008, 13:10   #5 (permalink)
Member: 269202
only use 7 pin cable and if you have used 7 pin with this problem your cable is fault
Old 06-02-2008, 13:21   #6 (permalink)
tunjay-gsm's Avatar
Member: 338192
Sonork: 112568
Originally Posted by DARIFBS View Post
if cant fixs pls download this http://www.teamviewer.com/index.aspx
than give me control we tray fixs together pls add me my msn --tunjay@australia-gsmworld.com
Old 10-05-2008, 23:19   #7 (permalink)
inside-d-saul's Avatar
Member: 581626
Nokia 6110n flashen error
i use Twister with orig. HWK (latest version v8...) i have flashed many BB5 phones without problems and now
iam trying to flash nokia 6110n but always the same error like in the above image(from DARIFBS ).
Please help
Old 10-07-2008, 16:27   #8 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
My problem sloved when i modifie the cable; the correct pinout in attachment!
6110n after flash set dead woreal.gsm Nokia Base Band 5 ( BB-5 ) 4 05-28-2008 18:48
My 6110N cant flash! help me! c8387811 MT-BOX 11 09-19-2007 10:17
error flashing Z-1010, Error Flashing V-800 juliog SonyEricsson (USB-Smart) 2 09-14-2005 12:31
Page generated in 0.34510 seconds with 12 queries
