Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-29-2009, 12:33   #1 (permalink)
Member: 823633
Thanks Meter: 1,705
6233 help
6233 flashing ok v 5.60 ok
imei is ok but probalab is
music player music on autometick powar off help
Old 08-29-2009, 12:51   #2 (permalink)
Member: 310155
Thanks Meter: 1,313
post ur phones full log.
Old 08-29-2009, 13:10   #3 (permalink)
Member: 823633
Thanks Meter: 1,705
bro my 6233 cyclone logs
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7880
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.06, (Aug 8 2009 17:54:19, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: Revised
Box Serial Number: C0000949
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Initializing security card...
Card Serial Number: D20001EA
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.17v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.80v PASSED
VBAT Voltage 0.23v PASSED
VBAT Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 29 products, Filtering BB5 Products - wait...
9 Products left after filtering. Ready.
Retrieving Variants for Product RM-145 - wait...
3 Variants Retrieved
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000353
CMT_PUBLIC_ID: 0BC0000C7B5D63509FC9C41C6922900CD802198D
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID: 273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 2F36DDC4990FD844712A61A80C033211BD9602E3
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
WMDRM Store not supported
Booting RAP...
Box VPP disabled
Storing NPC...
CMT CCC Not Found
CMT HWC Not Found
Storing VARIANT...
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
MCU Version V 05.60
MCU Date 14-09-07
Product RM-145
Manufacturer (c) Nokia
IMEI 352915023583134
Mastercode 4541433225
Simlock backup OK, saved to RM-145_352915023583134_8292009_53424 PM.SLBackup.PM
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm123_145_30005.600.mcusw (CMT)...
Booting RAP...
rm123_145_30005.600.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Flashbus Write baud set to 51Kbits
Box VPP disabled
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0000FFFF, NOR
EraseArea[0,CMT]: 0x00010000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x000A0000-0x0021FFFF, NOR
EraseArea[0,CMT]: 0x00220000-0x011DDFFF, NOR
EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR
EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 73.47s
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT PMM_CONF Certificate...
Writing CMT SBIF_CONF Certificate...
Programming Status OK!
All blocks written OK! Time taken 107.172s
Restarting MCU...
Processing rm123_145_30005.600.mcusw (APE)...
Processing rm123_145_3005.60.ppm_w (CMT)...
Booting RAP...
rm123_145_3005.60.ppm_w, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x011E0000-0x016DFFFF, NOR
Erase taken 18.375s
All blocks written OK! Time taken 29.828s
Restarting MCU...
Processing rm123_145_3005.60.ppm_w (APE)...
Processing rm123_145_30005.60.image_w (CMT)...
Booting RAP...
rm123_145_30005.60.image_w, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x016E0000-0x01E7FFFF, NOR
EraseArea[0,CMT]: 0x01E80000-0x01FDFFFF, NOR
Erase taken 42.156s
All blocks written OK! Time taken 12.171s
Restarting MCU...
Processing rm123_145_30005.60.image_w (APE)...
All images processed OK! Processing post flash tasks...
Reading info...
MCU Version V 05.60
MCU Date 14-09-07
Product RM-145
IMEI Spare 33353239313530323335383331333400
IMEI SV 3A25190532851303
ESN OTP 3%2…ø
Basic Product Code 0528588
PSD 0000001F00000000
RETU 32
TAHVO 53
AHNE 30
HW 2010
RFIC 17211721
DSP pb05wk46v50
LCD SEIKO
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2440700000000000
Simlock Profile 8000000000000002
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 08-29-2009, 14:55   #4 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Initializing box...
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
Booting RAP...
Box VPP disabled
Restarting MCU...
Backing up RPL...
Storing PSN...
Storing HWID...
Booting RAP...
Box VPP disabled
Storing NPC...
CMT CCC Not Found
CMT HWC Not Found
Storing VARIANT...
Restarting MCU...
RPL Saved OK
MCU Version V 05.60
MCU Date 14-09-07
Product RM-145
Booting RAP...
Box VPP disabled
Erase taken 73.47s
Restarting MCU...
Booting RAP...
Box VPP disabled
Erase taken 18.375s
Restarting MCU...
Booting RAP...
Box VPP disabled
Erase taken 42.156s
Restarting MCU...
Reading info...
MCU Version V 05.60
MCU Date 14-09-07
Product RM-145
ESN OTP 3%2…ø
RETU 32
TAHVO 53
AHNE 30
HW 2010
RFIC 17211721
DSP pb05wk46v50
LCD SEIKO
Simlock Key Cnt 0
Simlock FBUS Cnt 0
bro.. this is not a Cyclone box forum post right section
Dead 6233 help 8210 MT-BOX 1 12-22-2007 22:21
Nokia 6233 help please! basmic Nokia Base Band 5 ( BB-5 ) 4 10-25-2007 19:01
6233 help xboy_smt Nokia Base Band 5 ( BB-5 ) 1 09-27-2007 19:48
Page generated in 0.27954 seconds with 9 queries
