08-28-2006, 17:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: eproom memory Age: 41
Member: 264366 Status: Offline Thanks Meter: 29 | 6680 Killed by HWK Please give idea The phone was working before flash , just want to flash to upgrade version ... the customer will get furious tomorrow ------------------------------------------------------------------ 1st BOOT : C0,0C HELEN ID : 17100701 HELEN MODE: 00 HELEN PBID: 6C141A43DE2DF195BB7715F0173E70220D0FBD3C HELEN HASH: 2C05369F57CC3C4CF9E783E83D9B512B HELEN ROID: AB5E4ADB27A06946 RAP3 ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAP3 PBID : 14000102737E4E51292B80DE4D61024FB6DA463B RAP3 MODE : 00 RAP3 HASH : E9EFF4BFAA5393217CA6B17755FC3E1401000000 RAP3 ROID : F28A211FCEA7B19D CMT 1st Boot Ok CMT 2nd Bt: RAP3Gv2_2nd.fg, Ver: 1.9.2 CMT FLID : 002088C0-00000221, St M28W640 CMT FLCNT : 000080008000800080008000800080008000 CMT 2nd Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.9.3 CMT Alg Boot OK Erase Area: CMT 0x00000000-00509BFD Erase Area: CMT 0x006DF000-006EFFFF Erase Area: CMT 0x00700000-007EFFFF Process Failed, Repowering Mobile --------------------------------------------------------------------- Now 6680 is dead |
08-28-2006, 17:59 | #2 (permalink) |
No Life Poster Join Date: Apr 2000 Location: near you Age: 60
Member: 1196 Status: Offline Thanks Meter: 6 | check chinesse cable ,bad connection ,you dont need ext batt 9V,my HWK flashed my 6680 fine ,,and everything work nice,,but I have troubles with HWK cables and contacts in the first time + an - were broken contacts on small PCB..find schematcs of UFS/HWK 6680 flash cable ,,don't worry it is not so simple to kill this phone with HWK.maybe you use lower flash version,find latest V 5.04.07. and flash again ,,everything will be fine |
08-29-2006, 20:50 | #3 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | I'm using V5.04.07 flash brother ... I check with two diferent cable but same thing ... Also I Flashed with another Box HWK from a friend , same thing ... PLEASE ANYBODY HELP . . . |
08-30-2006, 19:17 | #5 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | Yes maybe you are right i will try tomorrow me also already flash the more than 10 times but always same eroor . I'm going mad with this phone guy ... |
08-31-2006, 02:18 | #6 (permalink) |
Junior Member Join Date: Apr 2005 Age: 47
Member: 141329 Status: Offline Thanks Meter: 1 | why don't you try this, it might help. Before attempting to flash the phone, connect charger to the phone and to wall outlet (just like you charging your phone). Then flash it. From my experience, I had this problem with my N91 (BB5 phone) 3 weeks ago, it was completely a dead phone. I just did what I said above and my phone came back alive again. |
08-31-2006, 20:58 | #9 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | Thanks for everybody posting solution . - TASURA : i will try to conenct charger when flash . Thanks ... - JOSETOLO_JR : when flashing with erase files is there not a risk to lock the phone . and unlock BB5 is not possible Thanks everybody |
09-02-2006, 22:22 | #11 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | I'm really fedup with this mobile 6680 . I've tried to connect charger but always same error . I've tried to rehot the flash Ic and now only 1st book is ok 2nd boot error . Someone already face this problem , any idea to solve it ??? |
09-03-2006, 19:06 | #12 (permalink) |
Junior Member Join Date: Dec 2005
Member: 205446 Status: Offline Thanks Meter: 0 | @johnreza hi had same prob with 6630... are u using original hwk or clone or test one ....??? have u ever applied what is called hwktool, hwkemu to the box if i am not worng there are two types of cables available one 5 pin and other 7 pin. try for 7 pin one and most imp. post results we all help each other by trying out... isn't it. good luck.... bye |
09-05-2006, 06:44 | #15 (permalink) |
Member: 205446 Status: Offline Thanks Meter: 0 | @johnreza when u are having original hwk why are u using hwk killer i think u are having a clone or self distructed hwk try with someone having original hwk i.e. updated online with saras meanwhile if u can have a hold on jaf i think that can solve ur problem and pl. post results for others to share bye |
hwk please give solution to unlock w530i | sam22001 | HWK | 1 | 08-05-2008 09:50 |
SE Z300i DEAD, KILL BY HWK and me | adrianw23 | HWK | 3 | 08-22-2006 13:33 |
Need HELP U8550 killed by HWK . | johnreza | HWK | 5 | 06-30-2006 18:41 |
